Any news if this new version still have the same hardware ?
No, it has a new reivision, but due to the problems I have actually hooking it up to a computer, we cannot dump the files on there to analyze or try the IR sensor modifications.
I was helping someone on skype and they made the mistake of updating from 1.22 to 2.1 and they are having the same exact symptoms... its not even showing up on Flir Tools.
Okay,so that would mean my camera is not broken, that 1.2L is not proven broken yet, but the 2.1.0 firmware is causing this issue. Did you manage to resolve the issue with them?
- try with alternative cable - they sometimes break!
- do not use USB hubs
- try different USB ports
- visually inspect the socket (use magnifier)
- write down what OS and patchlevel did not recognize the camera
Already did those. I actually used 3 diferent computers. Windows 7 Ult x64, Windows 8.1 x86, Windows Vista SP2 x64 with FLIR tools 4.1.14066.1001 and driver 1.9.1.0.
- be sure to install flir player (comes with drivers)
That might be the missing link, I will try that right away
BTW, I also logged a support issue with FLIR about it. Let's see what they come up with.
