Edit:
Problem solved. Earlier I asked if it would be possible to pull the program (FLIR Tools Mobile) from another
device and plant it on my tablet. I did better than that, FLIR in Sweden emailed two APK files to me, I sideloaded
them on my tablet. The email was received on my PC, I connected a usb cable between the tablet and the PC,
copied the files, executed them on the tablet, and bingo, the program installed.
I suspect this is a common problem, but it took somebody in Sweden to fix it, although the local tech support
tried, they didn't solve the problem.
The wi-fi works great, I can now create a hot spot on my tablet, run the FLIR Tools Mobile, and see my camera,
edit the photos, etc. And of course, can do the same via the wi-fi in my office.
I hope this helps somebody who might have had the same problem, Sideloading!
Jim
I returned the tablet, got tired of fighting it, absolutely have to have google play store.
Got another with google play, downloaded flir tools mobile, now trying to
figure how to make the camera and tablet talk together. Flir used to have some tutorials, I can't find them.
If I remember right, I have to create a hot spot with the tablet, have the camera find it and connect to it, right?
I'm trying to find how to create a hot spot with this "Visual Land" tablet. Downloaded a hot spot app, onwards.
All works fine when I use my htc android phone as a hot spot, but it's screen is too small for this sort of stuff.
edit: I found a copy of the FLIR Tools Mobile pdf, but it simply wants us to connect us to a wireless network,
again, I believe the tablet has to create a hotspot, right?
Can somebody point me to some flir tutorials on pairing the cam and tablet?
Jim
