Camera (E40bx, ver. 490xxxxx) still works and works with 320x240 resolution!
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Should work with all Exx cameras I guess.
However, I have 2 questions:
- I can't get thermal fusion to work - any idea here?
- I can't change logo (FlashFS/system/bootlogo.bmp) - I created same size image and replace it, but no difference. Not a big deal actually, but would be nice.
Here are steps for dummies (like me!
- Download tools from
https://www.eevblog.com/forum/testgear/flir-e4-thermal-imaging-camera-teardown/msg321956/#msg3219561. Download E60 files from my previous post (E60 goodies)
2. Modify files with proper serial number and calculated CRC. Mind all described in CRC01 tool text file!
3. Download clonezilla
4. Turn on camera, connect it to wlan. Check its IP in WLAN settings
5. Connect to camera with clonezilla. Use IP, seen on camera WLAN settings, username "flir", password "3vlig"
6. Backup FlashFS folder - there are all files, that will be altered.
7. Replace files on camera with ones, that you created. I suggest only renaming original files with .old extension instead of rewrite/delete. This way original files are backuped on camera as well.
8. Shut down camera, remove battery, wait a bit and then turn camera on (offcourse insert battery first
) Voila!
EDITEDDue to unknown reason, with my camera (and latest Flir firmware - 2.23.14) this change only works in a following way:
- Do everything described above (DO RENAME OLD FILES!!!)
- Cold start camera (off, battery out, on)
- Connect to it back, and rename "new" files with .new
- Rename "old" files back to original name
This was it works! (also Thermal fusion!)
I would like to thank all of you guys for help you provided!
Regards,
Gregor
