But there is no config-File anywhere. Is it possible, that flir create this file in the system? And when all systems(E4 to E8) are on the same hardware, how do they separate them to set the correct factory settings?
up to now, config files are untouched while firmware update
Flir wrote this files while calibration of camera
-> in this case E4/E5/E6 gets the same update files
I several times ask in this forum what happens if a user makes a manual update from 1.19 to 1.21.
We know, that 1.21 boots successful without conf.cfc in native mode (80x60 without msx)
first i put the e8cfg in the folder, reset to factory-> no changes
next i delete the old conf.cfc-file, reset to factory->no changes
.caps.config: (3)
rw--r--------- 0 root root <e> image
r---r---r----- 0 root root <a> name "" // empty configuration name!!!
.caps.config.image.settings: (4)
r---r--------- 0 root root <i> IRheight 60 //no high res mode
r---r--------- 0 root root <i> IRwidth 80
It's possible, that a manual update without new conf.cfc from 1.19 to 1.21 results in a slightly bricked cam (80x60 without msx) and the TIC needs a flir service
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
Anybody knows, whether Flir Tools offers a (automatic) update from 1.19 to 1.21. for the E4/E5?
I do not expect it...
There are many hackable Flir TIC on the market (we know ix, Ex, Exx and possibly more series like Kxx).
Flir until now never delivers upgrades for old series.
Let's wait and see the strategy. Ebay will push the old cams
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
