Hello everyone, Ive been reading since the first post happened and have been following as a guest on and off for a few months to catch up on what is the best
thread I have ever followed in my life.
I bought an E5 back when they came out and shortly after stumbled upon Mikes review. Well like most of you, got fiddling with my new instrument and since then cannot put it down.
I have a few questions about the hacks
I have used other FLIRs to inspect asphalt paving at work and created reports with them no problem.
I guess this is where my main question is: Since I first did the E8.cfg hack, the images I import have a misalignment with the 2 bit layers of the image. As in when I try to see what a temperature is on the image of say a hot pipe, the report software says that the hot spot is lower (about 40 pixels lower).
Now this happens in FlirReport, FlirTools, you name it.
Heres a Picture of a water heaters hot pipes so you can try to see if its my computer or if its the camera. See if everything matches up.
The camera works fine = hotspots match up with hot stuff and cold with cold etc... just that it doesnt work when I want to make a report on my computer. I can fiddle around and eventually find it but its not there where it should be.
I still would like to thank Mikeselectricstuff and Taucher for making me really really enjoying my purchase. 120x90 wasnt too bad for 1595$CAN but I always wanted to buy another camera later... not needed anymore. (oops sory FLIR)
Sorry for the long post but also had another question about the Flirlogo. If there was a way to have it like a faint faint watermark on there of another logo of my choice?
Sincerely, Yohann
