I installed tauchers beta3 menu hack last night, i followed the instructions, dropping the new flashbfs file onto the flashbfs on the camera. When I restarted the camera(removed the battery) nothing had changed. Looking at the new flashbfs file on the camera, the flashbfs folder that i moved, became a sub folder inside the cameras original flashbfs folder. So I deleted the extra folder, and dropped the settings folder from the new beta3 flashbfs into the camera flashbfs folder. This time the hack worked, i played with the menus and it all worked fine.
This morning i was using the camera, trying out the new menus, went on the displays, i think i was on the small picture in picture . When the screen froze , and there were vertical strips about 3 to 4 mm wide, alternating normal image strips and strips with distorted image(digital noise). I did a restart, and it was ok.
Does anyone know what might cause this to happen, and any suggestion on what to do, to stop it happening again.
Thanks
