Folks
Hi, I'm new member from Japan and a i3 user.
Thanks a lot of your geek activity, I'm enjoying TIC mod life, too!
So I'm going to feedback something..
1)Any ID/pass combination are available for FTP.
Not only flir/3vlig for ftp log in.
2)The i3 has a hardware reset button.
Left of the Li-ion battery connector.
This button functions equal to "Battery remove & connect again".
3)My i3 is now 240x240 of resolution!!
That is "over-i7" monster.
i9?
Following picture is a comparison that i7 mod vs 240pix with same distance.
Now I got more broader FOV.
To mod:
a) Upgrade to i7 with Erik's
https://www.eevblog.com/forum/testgear/flir-e4-thermal-imaging-camera-teardown/msg348174/#msg348174 b) Edit conf.cfg file for service mode (FlashFS\system\service\appcore.d\config.d\)
".caps.config.image.settings.resIR int32 144" to ".caps.config.image.settings.resIR int32 240"
".caps.config.image.settings.fpgaResolution.resIR int32 144" to ".caps.config.image.settings.fpgaResolution.resIR int32 240"
then Filestamp, adding CRC, Filestamp, and FTP.
c) Connect i3 to your PC with RNDIS mode and activate the service mode.
d) 2hrs after power off, "i9" will back i7 resolution.
Maybe "resIR" stands for "resolution of IR image"..
Issue1:
At the moment, this config cannot apply with normal mode.
Service mode might have less secure config checking system than normal mode.
Issue2:
"CSV output" resolution from FLIR Tools, now 120x120 at service mode, , another tricks?
Cheers,
Shimalith
