I was mainly responding to the logic,
Can you explain why you think I am rotating the whole imaging system when I use my focus tool? I've not looked inside my camera but I kind of assumed I was just rotating a lens with the focus tool and not the 'whole imaging system'. Just wondering if there's something wrong with my reasoning (or yours )
I cannot explain that. I can however explain why I think that
pointing the camera at something, taking a picture, then rotating the camera and then taking another picture is rotating the whole imaging system. Which is what I
thought you said. But given your reaction now that you mean just rotating the lens, and reading it back
"... eg point it at a desk and rotate the focus control" I take it you mean that you keep the camera steady and only rotate the lens. In that case no arguments from me, because that is exactly the same thing that Aurora was talking about. So my bad, I cannot read.
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
And all that after I just typed up a response about the signal path, but after I reread your response that is now a moot point. *pout*
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
Going back to the original subject, you have pointed the camera at a steady uniform surface, then rotated the lens and no differences to be seen? If yes, then that is good news. How good the news is for those of us with banding etc would depend a bit on if your calibration/correction pic shows any banding. If your .gan/.crs shows banding + you get no adverse effects under rotation ==> joy! If you don't have banding to begin with then this good news for you doesn't automatically translate into good news for those of us that do see some banding in the calibration picture.
