Ok, I couldn't resist to stop this whole "guessing" about the new tools (what a waste of time):
Direct link:
http://cdn.cloud.flir.se/update/flir%20tools/4.0.13330.1003/flir%20tools.zipFirst let's take a look at the list of the last available updates:
FLIR Tools / FLIR Tools+ 4.0 (4.0.13330.1003)
FLIR Reporter 9.2 PRO, 30-Day Evaluation (9.2.13330.1001)
FLIR Sensor Manager 3.10 (v3.10.0.0)
FLIR ix v6.5.3 Update Pack (P/N: 6010X-XXXX)
FLIR Exx P/N:645xx / 646xx (3.12.7) Update Pack
FLIR Kxx (1.19.9) Update Pack
FLIR Ex (1.18.7) Update Pack
FLIR ResearchIR MAX 3.5 with SCxxxx and Xsc series drivers, 30-Day Evaluation (3.5.13277.1001)
FLIR ResearchIR 3.5, 30-Day Evaluation (3.5.13277.1001)
... ok, as expected the tools got updated.. nothing exciting yet ...
Then let's look at the differences in newest Flir Tools - compared with previous version:
(unpack .zip, unpack .cab files etc)
Findings in short:- Flir removed lots of old, binary stuff inside prerequisite directories (VCredist etc. - no Flir code)
- They kept language packs unchanged in size
- If something got changed, then mostly just version numbers, but not sizes for most files
- Only relevant changes are inside report generator and clearly office-report-integration-related
They just cleaned up some office integration with the new tools - so please stop panicking!In more detail:
Inside flir tools.cab:- file_FLIR_Tools_Updater.exe is UPXed... but unchanged ...
- file_FLIR_Tools_Updater.dat (
PKzip file, PW is "99B2328D3FDF4E9E98559B4414F7ACB9" ![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
... got changed due to version information strings:
_TUProj.dat-> old: "
http://cdn.cloud.flir.se/update/flir tools/4.0.13284.1003"
_TUProj.dat-> new: "
http://cdn.cloud.flir.se/update/flir tools/4.0.13330.1003"
that .dat file beeing some .lua script made by/for TrueUpdate 3.0 - whoever likes to take a look - now you know where...
The URLs above seem to be some webservices or to require getting/posting some additional value
Also possibly helpful: /CHECK_UPDATE_AVAILABLE_ONLY
Other files from the .cab:
DynamicDataDisplay.dll ... recompiled with new version info, no relevant changes
file_Flir.Configuration.Configurator ... recompiled with new version info, no relevant changes
...etc etc...
file_Flir.Modules.Common - gained some bytes
file_Flir.Modules.Organize - gained some bytes
file_FLIR_Tools_Updater.dat - changed size due to compression - see above
GoogleAnalyticsTracker.dll <- WTF?!... excuse me - are we spying on our customers?! (same size, change just recompile/signed with up2date key)
--- NO other changes there in the tools ---Inside flir word reporting.cab: - IRSummaryTable (minor changes)
- IRTable (minor changes)
- RapidReportCreator.exe (minor changes)
- WizardClassLibrary.dll (minor changes)
... plus some updates for version information - but no functionality
File: configureoffice.exe -> got removed...
Conclusion again: They just cleaned up some office integration with the new tools - you can stop panicking and stop comparing hashes now ![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
