Also, what is the name of the drive? I noticed that it says untitled and pretty sure that it didn't before...
interesting... Version.rsc has serial and a CRC...
so here the E60 files I used for my E30, pw funzt666
but remember do it by your own risk, I had some bad starts with my new E60, but together we will win!
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
So if you need more please ask!
E30 has same components inside, WLAN and bluetooth is on board!!!
So it regognize my WLAN android hotspot, but FLIR mobile doesnt see my cam
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
Im not ready with it, ...
but good news: it works as good as the orig E60 I have rent
The user drive is \FlashIFS, though I have occasionally seen it get mounted as FlashIFS2 - I think this was when service mode was active.
If you're not seeing this from FTP this would explain why saving isn't working
Interesting... When I first started FlashIFS was there... Now its not... Trying to recreate it now...
Could be some corruption - might be worth renaming FlashIFS and creating a new one - renaming may be safer if contents are corrupt.
Remember FlashIFS
will disappear when you connect with MSD, and will take a few secs to re-mount when USB is unplugged or USB mode changed
Mike - I think you are onto something... FlashIFS is not there and when I created the directory, it got deleted...
When I look now its not there at all in Filezilla...
Remember FlashIFS will disappear when you connect with MSD, and will take a few secs to re-mount when USB is unplugged or USB mode changed
Got it recreated, no joy... Wondering what the contents of flashIFS are vs what you see when you MSD...
FlashIFS should be the same as what you see via MSD, which is also what you see via the virtual drive that Flir's toolbar util sets up when the unit is in RNDIS mode.
Actually I wonder if this could be an issue - if this util is running may be worth trying stopping it, though AFAIK it's just an FTP link so shouldn't stop normal FTP via RNDIS working.
There is a utility in wither Windows of FlashBFS\system that will show some info about the flash filesystem - don't recall the name but it is fairly obvious - may be worth trying this (via telnet console)
Console may also be a more reliable place to look at directories, attributes etc.
Ok, that seems to be the issue. What I see via MSD is not the same.
AND any attempt to recreate FlashIFS is not sticking...
I wonder if any distributors will have Black Friday discounts tomorrow.
Wondering if it had a hardware prob to start...
Now its stuck on the flir startup screen and won't do anything... ARGH...
A bit more info about the defective camera.. I let it sit overnight and this morning noticed that when it first starts up, there isn't as much of a temperature gradient problem. I took a snap when it started up and once a minute for the first 5 minutes. You can see that the gradient forms when its internal electronics begin heating up. This time, the inner aperture moved a bit and the gradient is now top to bottom.
These are all with the cover closed and the unit sitting still.
I'm curious to see what someone else's model does in the first 5 minutes of startup after sitting several hours to cool off.
I got a message today: New FLIR Tools Version
Should we be worried?
In the "read more..." link: <li>Camera update (applies to FLIR Ex, Kxx, Exx and T6xx series only).
Just seen the same. Would they dare implement an auto firmware update
Well, try out and tell us
![Evil >:D](https://www.eevblog.com/forum/Smileys/default/evil.gif)
... just kidding ... why risk something? Old Flir tools are working fine.
That camera is defective.
There is no temperature gradient on my E4 and the display stays a nice even orange colour when the camera is in auto mode. When looking for temperature drift it is best to use a very small span such as 2 or 4 degrees Celsius.
$ 4 degrees can be achieved on an E4 with upgraded menus offering manual span. I find Auto mode sticks to large spans of 8 Degrees or more. If yo are seeing gradient drift at wider spans, it will be truly awful at 4 degrees span.
As I previously stated, I recommend you exchange your unit ASAP.
This is one of those times where you should actually read (I know) the EULA. If the new version is going to automatically update firmware files on your camera, you'll have to agree to it somewhere for legal purposes
I am not going to update anything with this camera. No sense in chancing it.
Camera works just fine the way it is as an E4/8
True
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
It would be
way out of my league to mess with software on this level. I didn't save the complete ZIP of the last version but the new one's got a "terminatetrueupdate.exe" and it scares the crap out of an amateur like me.
I'm very interested to get time-lapse working. I have some strings seen in the firmware. Has the E60 this feature?
For those of you who imported a camera to your country via a third party (friend/shipping agent etc.) - have you registered your purchase with Flir?
I haven't done so yet but I'm wondering if there will be any 'complications'.
Hoping that they don't ding me too bad on the repair for mine...
![Sad :(](https://www.eevblog.com/forum/Smileys/default/sad.gif)
Dunno if the dog yanking the cord was the issue or not, but can't just straight up claim warranty...
Lesson learned.. No picture transfers near the pooch... (he is a tad rambunctious and got tangled in the usb when he jumped up on the couch
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
