Ordered 1 two for
1200 euro
will be delivered within 3 to 6 days.
Until then, I'm playing with a SC655 with a max of 200hz
Besides 9 Hz is fast enough for normal use. (30hz is obviously better).
> 30hz is good for measuring inrush currents or explosions etz.
I use the SC655 mostly @12.5hz.
By the way the I.mx257 has a USB host port!
Maybe one of the pins of the connector is equipped with USB
Or maybe is on the not assembled connector on the PCB.
(some sample pic's from the sc655)
