some basic i3 info from different posts in this thread collected together for newbies like me
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
simple solution that changes i3 temporarily to i7 but doesn’t void warranty as there no modifications to camera at all
- turn on camera
- press left menu button once
- press gallery (play) button for 5 seconds
you should have ‘diagnostic’ screen open
- under left menu, change usb mode to RNDIS
- install flir drivers
http://cdn.cloud.flir.se/swdownload/assets/other/flir_device_drivers.exe - connect camera to your pc
(at this point it should install as network card with dhcp active and camera should be accessible through www [port 80, there is also few more things active – check 3rd page of
http://www.imc-store.com.au/v/vspfiles/assets/images/flir%20a310%20technical%20notes.pdf ] rtsp stream is obviously not available)
- open your browser and navigate to
http://192.168.0.2 then activate service mode – user:flir password:3vlig
- give it 30-40 seconds without pressing any keys, it will reboot and it will have i7 angles and resolution on the screen
those changes are reversed with every reboot so reset it with a switch or let it turn off when you are done with it
sample pictures from my i3
![](http://img30.imageshack.us/img30/3989/30ht.jpg)
all informations quoted here were provided in this thread by various users, thanks lads
BTW, is there any way to reboot it without using hardware switch in battery compartment or waiting until it powers down by itself - long press on power button don't work for me at all
