Poll
275 (28%)
444 (45.2%)
49 (5%)
51 (5.2%)
164 (16.7%)
Total Members Voted: 805
Author Topic: Flir E4 Thermal imaging camera teardown  (Read 3997782 times)
0 Members and 25 Guests are viewing this topic.
Offline BravoV
  • +++ ATH1
« Reply #625 on: November 05, 2013, 03:54:39 am »
You're right, post updated with link to post #524.
Offline Rasz
    • My random blog.
« Reply #626 on: November 05, 2013, 05:17:11 am »
In case anyone is unaware....a TIC will NOT see through glass so you would have to open a window to see outside.
unless you are muOptics!
Offline ViciousPest
« Reply #627 on: November 05, 2013, 08:14:04 am »
Long time listener first time caller. Just ordered my E4. So if I read all 45 pages of the thread its no longer considered an impulse buy, correct?   :-// Regardless. I assume many of us will be receiving our E4 shortly. Has anyone confirmed that they are shipping with a newer fw? I saw a post about 1.19.x being on the device. I doubt they would be able to patch it that quickly.
Online mikeselectricstuffTopic starter
    • Mike's Electric Stuff
« Reply #628 on: November 05, 2013, 08:15:38 am »
Re. the i3/7, if it is the same as the E4, then the EEPROM is not where you need to be looking.
On the E4, the  configuration comes from the conf.cfg file, which is protected by a CRC01 and having the serial number in the file to prevent copying between units.
There are at least a couple of people here with i3/i7 - maybe they could investigate further - I suspect the E4 hack method, or something very similar may well work on the i series
Day Job: Mostly LEDs
« Reply #629 on: November 05, 2013, 08:26:13 am »
Tequipment's stock of E4's has gone from 12 yesterday afternoon to 5 now...
Offline amyk
Offline Zoltan von Negrow
  • Country: cz
« Reply #631 on: November 05, 2013, 08:54:10 am »
Is there something special about this cable?
No, it´s normal USB-A - Micro-B USB cable
You can use standard micro USB charger for charging E4
« Reply #632 on: November 05, 2013, 08:55:13 am »
Only that it plugs into a $xxxx device - I wonder if anyone has ever bought one..?
Offline Taucher
  • 1DsaYDGWXEYhEKL rfrbFyYsehaAtfBWawf
« Reply #633 on: November 05, 2013, 09:01:26 am »
Mike - you wrote once something about 336x252 (or similar) physical sensor resolution...
Did you try out what happens when setting the resolution to the sensor's phys max or even above (or E6 res for example)?
Like whether the full res. then gets saved to files/snapshots or is beeing presented over USB.
Currently I'd assume that the cam always outputs 320x240 on all channels as I didn't see saved images with just 80x60 pixel resolution yet.
Offline Richard Wad
« Reply #634 on: November 05, 2013, 09:07:04 am »
lol, wow... 75$ for a 1$ cable.
my cell phone usb cable works just the same as the one included with the e4
« Reply #635 on: November 05, 2013, 09:14:18 am »
Not me - I don't recall seeing that resolution referenced anywhere. Sometimes visible image sensors have additional rows/columns for calibration purposes -e.g. masked to get a dark reference No idea if TIC sensors do similar things
Offline Taucher
« Reply #636 on: November 05, 2013, 09:36:48 am »
Ah, sorry |O  didn't see the italics (print view) and overlooked the initial line in post #261 ... plus now I remembered that you did connect a probe to the sensor and that you said something about 320x240 x 60Hz as output. ...
...and before I forget: THX to all you guys who cooperated on this thread  :-+
Offline amyk
« Reply #637 on: November 05, 2013, 10:38:30 am »
I could imagine a management-level purchaser being convinced into buying one for each of the cameras in a large order, "because the video has less noise using our cables" :-DD
Also curious if there's something in the warranty statement about it being void when the unit is used with "third-party accessories"...
Offline Taucher
« Reply #638 on: November 05, 2013, 10:47:21 am »
OT / @Cable: this reminds me of a 140 DM (yes, long long ago - nowadays it would be 140€) iLink(aka Firewire) cable (1,5m) ... specialty: was branded Sony and had a nice purple plastic instead of generic black ... of cause it was next to the camcorders ... approx 20m distance to the normally overpriced cables :)
Offline Pinkus
« Reply #639 on: November 05, 2013, 11:43:23 am »
Another possible feature for a MCU add-on - timelapse mode.
You could maybe also do auto shoot on detection for wildlife/security by looking for a rise in the temp scale (you can read this via level and span commands).
Good idea. I could not find the possible/allowed UART commands / parameter in this thread but I may have overseen them (due to the size of 46 pages I did just a quick scan). Can you please point me to the correct place or restate them? Thanks
Oh, and I am sorry for your cable! On long term it might be better to repair with another short FPC cable (add solder on one cable, then place contacts to contacts of old/new cable and heat from the top, that works pretty well).
« Last Edit: November 05, 2013, 11:46:44 am by PeterK13 »
Online AndyC_772
« Reply #640 on: November 05, 2013, 11:51:03 am »
The Audiophool industry has got there already with USB cables. Try a search for "oxygen free silver usb cable" and prepare to cry...  :palm:
Offline olsenn
« Reply #641 on: November 05, 2013, 12:46:22 pm »
The cryro-treated, oxygen-free, OCC silver USB cable with gold injections really brings out a subtle sibilance and a rich, lushous, tonally neutral, punchy, forward soundstage.
I almost forgot, it also reduces aberrations due to the skin effect!
« Last Edit: November 05, 2013, 12:48:41 pm by olsenn »
« Reply #642 on: November 05, 2013, 12:47:11 pm »
It's the T59504PDF linked here
https://www.eevblog.com/forum/testgear/flir-e4-thermal-imaging-camera-teardown/msg316284/?topicseen#msg316284
Offline equinoxe
« Reply #643 on: November 05, 2013, 12:51:17 pm »
I cried when a audiophool "explained" that his "special" hDmi (where the D stands for DIGITAL!) cables enhanced the sound and image of his (encrypted!!) signal..
A phool born every minute..
Offline olsenn
« Reply #644 on: November 05, 2013, 01:19:16 pm »
I just noticed that e4hack3.zip has been downloaded 129 times already. Undoubtably not all of those were from owners of an Ex camera, but it's nice to see that people are grabbing copies of the file before the thread gets deleted... you know, just in case :)
Predator vision is in transit!
Offline 0xdeadbeef
« Reply #645 on: November 05, 2013, 01:38:27 pm »
Talking of predator vision, even though a bit offtopic:
http://www.trotec24.com/en-de/measuring-instruments/temperature/infrared-cameras/ec060-v-infrared-camera.html
Claims to have 50/60Hz frame rate. Features video output, 160x120 sensor resolution, PIP and manual focus.
The onscreen display looks a bit unprofessional though, also some people on Amazon complain about build quality (battery charger etc.).
« Last Edit: November 05, 2013, 01:56:30 pm by 0xdeadbeef »
Offline _Sin
« Reply #646 on: November 05, 2013, 01:45:04 pm »
FWIW, if anyone is tracking, I just got an E4 with a serial# north of 5k, and firmware v1.19.8.
I'll definitely want to be able to focus it a bit closer, so looking forward to seeing any of Mike's experiments in making a tool to adjust that easily.
Have already spotted a possible irregularity with the office air-conditioning... it's not a toy, honest!
Programmer with a soldering iron - fear me.
Offline olsenn
« Reply #647 on: November 05, 2013, 01:46:08 pm »
Mike, can the E4 be hacked to provide 30/60 Hz refresh rate? I imagine the 9Hz operation is not limited by hardware but rather by export law.
« Reply #648 on: November 05, 2013, 01:56:19 pm »
One thing to check - the main obvious bug in the older FW is it doesn't show time/date in the file information - is this fixed in 1.19?
Offline Pinkus
« Reply #649 on: November 05, 2013, 01:57:00 pm »
Thanks Mike.
I assume it is chapter 4.2.4.5 on page 59.
But how do I send the command?
Like this below if I want a span from 0°C to 100°C (=273 / 373 Kelvin)?
38400 Baud; ASCII through RS232 interface:
"rset .image.contadj.adjMode manual CR/LF"
"rset .image.sysimg.basicImgData.extraInfo.lowT 273 CR/LF"
"rset .image.sysimg.basicImgData.extraInfo.highT 373 CR/LF"
Thats all?
Is CR and LF correct or only CR?
