Poll
275 (28%)
444 (45.2%)
49 (5%)
51 (5.2%)
164 (16.7%)
Total Members Voted: 805
Author Topic: Flir E4 Thermal imaging camera teardown  (Read 3957453 times)
0 Members and 25 Guests are viewing this topic.
Offline olsenn
« Reply #575 on: November 04, 2013, 02:05:20 pm »
I ordered one from tequipment yesterday and they have (or had at least) several in stock
Offline pmcouto
  • Country: pt
« Reply #576 on: November 04, 2013, 02:58:26 pm »
Today I had an “official” E8 in my hands and the lens is the same as E4 – At least, there’s no visible difference.
The MSX feature is very useful, even at 320x240.
P.S.
No, I was not shopping for a new E4  >:D
I already have an E50.  ;D
Offline zapta
« Reply #577 on: November 04, 2013, 03:21:02 pm »
Flir has a new market opened for it, TIC's for people that don't really need it.
Offline Petrlib
« Reply #578 on: November 04, 2013, 03:23:12 pm »
Hello my friends. I am just waiting for my new E5. Will be possible to do "E8 hack" on this device too? Will be complicated to do for newbies as I am? Sorry for my not perfect english but I hope you will understand..
Offline nova1200
« Reply #579 on: November 04, 2013, 03:31:21 pm »
Also regarding the lens, FWIW, it seems both E4 and E8 list the lens model as "FOL7" in their image metadata, and least based on an early E8 image found on the web. I used exiftool to dump the info; very nice tool which can also extract the raw thermal and visible images from a FLIR jpg.
Offline Pinkus
« Reply #580 on: November 04, 2013, 03:35:22 pm »
The serial of my E4 is 639047xx (last two digits are replaced by 'x'). I assume 639 is set as model number; as Mikes serial is  639037xx. So a few thousands are in the market (if they started with 0).
I've not really looked at features of the E8 compared to other units at a similar price, but £4700 seems a lot for a unit with no manual focus, manual temp range selection, wifi, touchscreen etc. even compared to the FLir Ex0 series.
I think the E4 E8 is pretty usable now, the only feature I am really  missing is the manual temperature range selection. Wifi etc. would be nice but is not really important.
Mike: as I remember correctly, you mentioned a few days ago, that temp. range selection can be done through the UART interface. Will this be possible any time in the regular shooting mode? Then a small ATTiny solution could be possible: By using an incremental encoder with pushbutton function there would be only one external item as the user interface needed. The display would then show the selected temp. range anyway.
Offline Pinkus
« Reply #581 on: November 04, 2013, 03:37:58 pm »
FOL is just the focal length. As the focal length is 6.5mm they are rounding up to FOL7.
Offline Fraser
« Reply #582 on: November 04, 2013, 03:40:04 pm »
Regarding buying a TIC that you don't really 'need'...... I am fighting the urge to buy an E4. I already own several thermal cameras, four of which outperform the E series. BUT I still like the E4 with its upgrade potential. I believe it is a psychological  thing....being able to buy a relatively cheap model and upgrade it to a more expensive specification. My heart wants one but my logical side is holding me back due to the lack of manual modes and less than simple adjustment of focus.
GBP960 is still a lot of money to your average Jo, and I am no different.
Online mikeselectricstuffTopic starter
    • Mike's Electric Stuff
« Reply #583 on: November 04, 2013, 03:54:56 pm »
Yes - it's just a couple of console commands (span and level I think). You need to be in locked temp mode - not sure if you can lock/unlock via the console but may be possible. I think the values are arbitary numbers, but the onscreen temp scale does update.
I suppose one option would be to do a board that sits inline with the keypad cable and connects to the serial FFC connector. And work out some magic key sequences to activate your functionality.
Another option may be to mod the battery base to add buttons.
or an accelerometer that recognises a 'magic shake'
or a hall sensor so you can use an external magnet to activate.
You may be able to read data via the console to infer enough info about the UI state to be able to activate & control a mod board - you can certainly read the current span and level, so if these freeze you an infer that the range has been locked.
there might be a way to read button states as well.
While you're at it another handy extra may be a freeze button to hold the current image, again easy to do with the console.
I wonder if you could slip in a touchscreen, or some capsense buttons between the screen and the fascia?
Day Job: Mostly LEDs
« Reply #584 on: November 04, 2013, 03:56:02 pm »
well you could always sell one of the other ones.... (BTW was it you that picked up that Irisys people counter? - PM me if you want to sell it)
Offline mrflibble
« Reply #585 on: November 04, 2013, 04:00:45 pm »
That's also what I recall, the temp range being settable through UART. I was thinking of an msp430 + buttons (or capsense slider) + bluetooth module as possible battery slurping additions... Or maybe an accelerometer to give it the secret handshake. :P The usability would depend a bit on how fast the respons to a range set command is + any easy to operate locations for a button.
Offline mrflibble
« Reply #586 on: November 04, 2013, 04:04:35 pm »
Yeah, thought about the mcu-in-the-middle as well for the keypad. But then you'll have to keep track of the UI state, which can get annoying real fast.
And touchscreen would indeed be funky, but that only gets to be meaningful (IMO) when you can integrate that properly into the GUI. Otherwise it's just too much hassle for what you get in return.
Custom GUI anyone?  ;D
Offline Fraser
« Reply #587 on: November 04, 2013, 04:10:41 pm »
Hi Mike,
Sell one of my 'babies'  :scared:
I may sell a Talisman but the FLIR PM570's and 695's are ITAR liable so selling them is complicated  ;)
Yes I bought the IRISYS people counter.
The rear labelling says:
IRC 1004-3
CAN Master
I have not used it so would be willing to sell it on as I have other projects to get on with.
IRISYS told me that it can be easily accessed via the low voltage RS232 serial interface. I was also given the software to do so. Itsin very nice condition and has not been taken apart  :)
PM me what you think it is worth to you and I will provide a fast response.
I attach pictures.
Offline firewire
« Reply #588 on: November 04, 2013, 04:20:46 pm »
I know a few people have posted where they purchased their unit and the price. Can we start a list of Supplier names and prices?
I'm sure there are many more ready to hit the go button. Thanks
http://www.valuetesters.com/flir-e4-thermal-imaging-camera-msx-enabled.html Advertised price is $995, but $895 if you "request a quote via email".
« Reply #589 on: November 04, 2013, 04:22:04 pm »
Not necessarily - if you could just add maybe a strip at the bottom or side using a thin PCB, you could create some virtual buttons at fixed positions just outside the visible area - you don't really need much - just an up/down for span and level when you detect that locked mode has been entered.
Offline cyr
« Reply #590 on: November 04, 2013, 04:24:33 pm »
Resistance was futile, another E4 sale thanks to Mike...
Offline termi
« Reply #591 on: November 04, 2013, 04:28:22 pm »
Another one sold ... couldn't resist for <USD880 shipped   ;D
Thanks Mike and eevblog community!
« Reply #592 on: November 04, 2013, 04:38:48 pm »
From their website :
Value Testers sells worldwide.  Our sales people have a great deal of experience with international markets, as we have sold to almost 150 countries worldwide.  We provide excellent customer service that is based on building relationships with our customers who become our friends.  Value Testers helps customers to select products that exactly match their needs and at the same time are the least expensive solution.  We also help customers to find the best and resonably priced shipping.  We work as a team to help our customers.
Amprobe and Fluke products can be shipped only within US, as per agreement between manufacturers and US distributors.  The same relates to Thermal Imagers frequency 33kHz or higher.
33kHz?
Has anyone tried ordering from outside US?
Offline Pinkus
« Reply #593 on: November 04, 2013, 04:53:24 pm »
Not neccessarily: At least with the current firmware, most buttons do not have any functionality when you are in regular shooting mode. So you might either check for combinations like
Back-button (upper right button) pressed together with up / down and left/right
or just using these buttons as they do not have any function anyway:
Some ideas:
Enable manual temperature mode: pressing 'back-button' for >1 second
up/down: setting upper temperature (each short click +/- 0.5°C for example; each longer click +/- 5°C)
left/right: setting lower temperature
disable edit mode:  pressing middle button
Also a remember function might be useful: entering the edit mode and then pressing the middle push button first, will set the values used last time and exits edit mode.
Well, the above will work if you are not in locked mode, but it will also do no harm.
Any other ideas which could be useful and which can be set by the UART interface?
As my camera is still closed (only removed the front yet to get access to the UART connector): does anybody know how many wires the FPC for the keyboard has? I assume 0.5mm spacing? The current functionality indicates that the E4 is not using a matrix but single lines for each button = then 9 wires would be needed as minimum.
« Last Edit: November 04, 2013, 04:56:26 pm by PeterK13 »
Offline mrflibble
« Reply #594 on: November 04, 2013, 04:59:54 pm »
True, but for me that would be too much hassle for what you get in return. As in, if the only functionality I get is some fixed function virtual buttons, I think I would just go with some actual buttons. As for an actual touchscreen fully covering the LCD, do you think the case would accommodate that? I would expect so, but I haven't had an E4 in my hands yet.  :D
« Reply #595 on: November 04, 2013, 05:04:37 pm »
Not strictly true once hacked - blue-below and red-above palette options use up/down.
and you need to reliably determine when you are in regular shooting mode.
Look through the PDF linked a while ago that documents a lot of the comamnd line stuff.
Not offhand but have a look in the teardown vid in case you can see it.
I think it may be 1mm pitch - will check.
If you can get something behind the display window for some touch buttons I think that would be the neatest option. You could maybe even do sliders..!
« Last Edit: November 04, 2013, 05:06:55 pm by mikeselectricstuff »
Offline mrflibble
« Reply #596 on: November 04, 2013, 05:10:58 pm »
The FFC for the keyboard looks to have 8 connections.
Edit: and looks to be 1mm pitch yeah.
« Last Edit: November 04, 2013, 05:14:43 pm by mrflibble »
Offline ixfd64
    • Facebook
« Reply #597 on: November 04, 2013, 05:23:36 pm »
Does the original hack also enable picture-in-picture, or does that require additional steps?
Offline Pinkus
« Reply #598 on: November 04, 2013, 05:32:50 pm »
mmmh- 4x4 matrix then. The same PCB might be used for other Flir cameras where they are using more buttons.
Thats correct; I forgot that.
Not really, because if I recognize the pressed keys in parallel (= µC is not inbetween); the worst thing which could happpen, would be an accidentely sent manual temperature set which only would be accepted when in lock mode. However I shall add a time function that the edit mode will exit anyway after 5 seconds without any pressed key.
« Reply #599 on: November 04, 2013, 05:40:24 pm »
The only hack that doesn't do PIP is the very first one of simply running in service mode with no tweaked files.
