Poll
275 (28%)
444 (45.2%)
49 (5%)
51 (5.2%)
164 (16.7%)
Total Members Voted: 805
Author Topic: Flir E4 Thermal imaging camera teardown  (Read 3965233 times)
0 Members and 13 Guests are viewing this topic.
Online mikeselectricstuffTopic starter
    • Mike's Electric Stuff
« Reply #475 on: November 02, 2013, 09:28:04 pm »
Yep - just tested and it works. Just trying again from a clean boot with no pre-existing hack file
..and of course you should be able to use the same method to install a custom boot screen
Day Job: Mostly LEDs
Offline Wann
  • Mechanical engineer gone rogue
« Reply #476 on: November 02, 2013, 09:28:37 pm »
YAY!
Offline Wann
« Reply #477 on: November 02, 2013, 09:38:20 pm »
Confirmed  :-+
Ahhh. The resolution  ;D
Now everbody be quiet as a mouse. Maybe FLIR will not find out about this. Maybe we should delete the last hour of posts?  :scared:
Offline mrflibble
« Reply #478 on: November 02, 2013, 09:38:43 pm »
Neat!  :-+ Now there really is nothing left to do for when I get my E4.  ;D Well, except set up a toolchain and make some small apps. Or did maybe someone beat me to that as well? That would be awesome, because I'd love to get some details on how to set up the toolchain for this device. XD
Edit: forgot to ask, how much space is left on the flash device?
« Last Edit: November 02, 2013, 09:43:55 pm by mrflibble »
« Reply #479 on: November 02, 2013, 09:45:25 pm »
Only needs the camera.cmd in the zip
addfile flashfs/system/appcore.d/config.d/e8.cfg
Offline Wann
« Reply #480 on: November 02, 2013, 09:57:22 pm »
That is just too easy...
So when FLIR is uploading new firmware, we should basically be keeping our fingers off?
Or there's no way they can block this?  :box:
Offline Wann
« Reply #481 on: November 02, 2013, 10:00:49 pm »
173 MB...  :=\
Offline tnt
« Reply #482 on: November 02, 2013, 10:03:42 pm »
There is _plenty_ of ways they could block this ... too many to enumerate and I wouldn't want to give them ideas ...
« Reply #483 on: November 02, 2013, 10:09:43 pm »
Updated 3rd Jan - enabled zoom in .cfg for Taucher's Beta3 menu hack zoom function.
OK, so this is it.....
Seems to not be bothered about 7zip - I just used Windows "send to compressed folder"
Open E8.cfg in a PC text editor (not anything that will mangle linefeeds etc.!)
At the end of the file, replace xxxxxxxx with the 8-digit serial number of your camera
Save the file (Make sure there is exactly one CRLF at the end of the file)
At a PC command prompt, run
  CRC01 E8.cfg  (on the edited file)
This will display a line in the form
# CRC01 xxxxxxxx
Add this line to the end of the E8.cfg file, so it now looks like :
  # ID xxxxxxxx
  # CRC01 yyyyyyyy
where xxxxxxxx is your serial number and yyyyyyyy is the generated CRC
(should be exactly one CRLF after the CRC)
"CRC" is case sensitive - must be upper case. "01" is zero one
Save the file as flashfs\system\appcore.d\config.d\e8.cfg
Create a zip file containing the flashfs folder tree and camera.cmd
Rename the file from .zip to .fif
Install FLIR tools
Go to the install folder\bin
Turn camera on and plug USB in
Run FLIRInstallNet
Browse to your .fif file
Click Run FIF
Unplug USB, remove battery and replace
Enjoy!
To remove hack :
Run FLIRInstallNet, choose the "Remove_hack" .fif file
USB RNDIS MODE
Do not mess with if you don't know what you're doing!
You can easily brick your camera with careless console commands
If you don't know why you may want to use RNDIS, YOU DON'T!
RNDIS allows FTP and Telnet access, and access to service mode via web interface
web/ftp/telnet 192.168.0.2 login flir, pw 3vlig
To set USB RNDIS mode temporarily - until next hard restart
Run FLIRInstallNet, run the "Set_RNDIS_Temporary" .fif file
You will get a timeout error as it dumps the USB connection.
.fif Scripts are also included to set RNDIS permanently, and also remove permanent RNDIS
These add/remove the appcore.d\factory.d\zrndis.rsc file
When RNDIS is active, USB Mass sotrage and video mode are NOT available.
Access to files is still possible via FTP or the the Flir T3Mon virtual drive util that comes with the RNDIS device drivers
Note FlirInstallNet WILL work over RNDIS.
« Last Edit: January 17, 2014, 10:50:52 pm by mikeselectricstuff »
The following users thanked this post: De
Offline mrflibble
« Reply #484 on: November 02, 2013, 10:11:06 pm »
LOOOOOOL! Seriously? That is just too easy.  ;D Almost too easy.  >:D
173 MB...  :=\
From my notes I have:
FLASH:
Toshiba AX1682
TAIWAN 13159AE 3
TC58NVG1S3ETA00
SLC NAND FLASH, 256 MBytes
Used 83/256 Mb, that's pretty low usage. Which is a good thing. Plenty room for some extra experimentation. :) Not strange now that I think about it, since that flash will also have to store all the images. Right? I recall Mike mentioning only 1 flash chippie, and two seperate LPDDR's (fpga + cpu).
Yup. And I almost hope they'll try some. Preferably one of the predictable ones, because that way the solution has already been done. History, repeat.
Offline Wann
« Reply #485 on: November 02, 2013, 10:14:18 pm »
I tried running this in a terminal :-/O
rm -rf https://www.eevblog.com/forum/testgear/flir-e4-thermal-imaging-camera-teardownDidn't work.
Ah just kidding  ^-^
Offline tnt
« Reply #486 on: November 02, 2013, 10:20:19 pm »
But I'd be more interested to find out how that .exe gets a shell in the first place and if we can make a software that does it.
Offline Wann
« Reply #487 on: November 02, 2013, 10:22:06 pm »
My new boot screen:
The seat keeps the heat from my behind.  8)
« Reply #488 on: November 02, 2013, 10:31:28 pm »
Yeah, because it's soooo hard now.. - I suppose it would be nice to avoid needing the FLIR software. Nice of them to include all the tools you need ready in the box though!
If you could get the USB comms working standalone, you could in principle do something that reads out the serial no., merges and CRC's the file and copies in a single operation.
« Reply #489 on: November 02, 2013, 10:49:56 pm »
I wonder if a similar method would work on the i series - not sure if files are in the same place
Offline ixfd64
    • Facebook
« Reply #490 on: November 02, 2013, 10:51:01 pm »
A while ago, there was talk of a hidden menu that could be activated by a certain sequence of key presses. Has anyone found it yet?
Offline tnt
« Reply #491 on: November 02, 2013, 11:00:29 pm »
Well not really for the hack itself, just to be able to play and experiment with the OS. I don't want to have to use a FIF to switch it to RNDIS (then switch it back) each time I want a console.
« Reply #492 on: November 02, 2013, 11:07:03 pm »
I'm fairly sure you can do it by putting the rndis.rsc file in \flashfs\system\appcore.d\factory.d
This file is in one of the early hack zips.
with rndis the only thing you can't do is webcam mode - you can pull your saved images via the Flir toolbar thing, or FTP
« Reply #493 on: November 02, 2013, 11:12:57 pm »
Mike (and anyone else with an E4):
How useful would you estimate this particular camera is for taking images of PCBs, in enough detail to identify which components are getting warm (with or without the benefit of your recent work)?
Yes -
See pics on this post
The only issue at the moment is adjusting the lens for close-up focus -the lens can be adjusted without opening as it's only locked by the friction of the surrounding rubber, but it's a bit hard to grab hold of.
 I am working on a tool to do this, as well as looking at using cheap laser cutter lenses
Looking at the moulding on the lens surround could you make a tool out of polymorph? Just soften it and push it against the lens surround.
Maybe - problem is it needs to be rigid enough to push against the outer ring, but hollow enough to not block too much field of view - currently looking at a PCB ring with pins.
Just did a quick test impression with polymorph and seems to be pretty good - just need to figure out what shape the rest needs to be to a useful tool that can be used 'blind' while looking at the screen
Offline Wann
« Reply #494 on: November 02, 2013, 11:17:27 pm »
There is a
zlast_RNDIS.rsc in the firmware file for the FLIR iX series firmware. Could you just rename that file, or is the real RNDIS.rsc different?
« Reply #495 on: November 02, 2013, 11:33:54 pm »
There is a
Attatched are .rsc files for normal and rndis.
I'm not sure what happens if you have both - my best guess is they are read alphabetically, so to do rndis without touching the existing usb.rsc you may need to rename it to something later alphabetically.
(This may explain the  zlast name above)
The files are CR32'd, so can't just be edited without re-CRCing (method a few pages earlier here)
I did try making one that did all 3 protocols but it went a bit nuts..
BTW a reminder that the first thing you should probably to if playing is run RNDIS and use filezilla to ftp off a backup copy of the whole \flashfs structure, as this is all the data specific to your camera.
« Last Edit: November 02, 2013, 11:47:22 pm by mikeselectricstuff »
Offline Wann
« Reply #496 on: November 02, 2013, 11:40:50 pm »
So the zlast_RNDIS.rsc from the iX firmware file:
# USB mode MSD
.system entry
.system.usbmode text "RNDIS"
# CRC32 d51f0c78
and the rndis.rsc you zipped:
# Generated at 2000-01-08 21:43:17
# ID
.system entry
.system.usbmode text "UVC_MSD"
# CRC32 c37005c3
Hmm... That's the same as the usb.rsc you zipped...?
« Last Edit: November 02, 2013, 11:47:48 pm by Wann »
« Reply #497 on: November 02, 2013, 11:48:43 pm »
Oops - just updated zip file in above post with correct version
# USB mode MSD
.system entry
# CRC32 d51f0c78
Offline Wann
« Reply #498 on: November 03, 2013, 12:00:17 am »
Ahh. That makes sense.
So does the CRC checks the filename, or is removing "zlast_" via camera.cmd a possibility  :-/O
I've never worked with CRC before :-BROKE
Offline Wann
« Reply #499 on: November 03, 2013, 12:01:22 am »
Nooooo. It's the same CRC32 value for both  ;D
