I found a picture in the camera's memory. Perhaps this was the reason for the flashing. I looked at the dates of the changes. .How to re-flash 2.11.0?
I think that might the VOx uncooled thermal sensor has a problem of connection,
please check the connector or the golden wire is broken which connect sensor signal to pcb.
BTW, if it's a firmware problem usually has two conditions,
1.signature check failed: your camera will never login again.(stuck in FLIR logo)
2.an older mixed new firmware: the screen will be like water stains on it. (It ain't completely no picture)
