I bought an E4 a few days ago with firmware 2.11.
I want to upgrade it (Hack it) to E4+ but I cannot set the RNDIS mode.
I tried many times to change the default UVC and MSD but it does not change.
Is it disabled by Flir?
Is there any other way to connect to the camera?
Regards
Platonas
Update: I figured out the problem with RNDIS. It is not available via the camera's menu. I had to run the file "FlirIstallNet.exe" and load the appropriate "fif" file.
Now my camera E4 is an E4+.
Thank you 2lps for providing the solution to the 2.11 version. A big Thanks for the people that originally found the hack that makes us happier
