Hello, new to the forum, and new to IR imaging. I've successfully hacked my 2.3 E4 to the upgraded resolution and menus.
However, I'm trying to get the camera out of permanent RNDIS and having some difficulty. I followed the instructions on the fubar site. When connecting the camera to my pc, it will not assign an IP, and I'm getting a "Could not configure ThermaCAM" notification from the taskbar. I tried manually setting and IP, as well as disabling all other network adapters with no luck. I've also searched through this thread, but theres quite a bit of info here, maybe I missed it? Has anyone had any luck with an issue like mine?
EDIT: Finally got it to connect, but when running Remove_RNDIS_Permanent.fif, the camera is seen and connect, installation starts, but I'm getting;
"Camera command rm -rf flashfs/system/appcore.d/factory.d/zrndis.rsc
Received shell command message: Bad command or filename"
EDIT 2: Fixed by deleting zrndis.rsc from flashfs/system/appcore.d/factory.d/ on the camera
