Upload it somewhere and PM it to me + the info.
Thanks Signal32!
I have been messing around again and got the reshack (already had) and the menu for the E5 2.11. However the manual temp scale is still missing, but everything else works including zoom. Did manual CRC03 calculation and ftool encryption. Did not try to use the cfccfgv2.py this time.
I have compared the 2lps conf.cfc with mine, and I have several lines missing in my original file:
.caps.config.ui entry
.caps.config.ui.image entry
.caps.config.ui.image.adjust entry
.caps.config.ui.image.adjust.enabled bool true
.caps.config.ui.image.adjust.manual bool true
I did include them on my conf.cfc prior encryption but then it ruined the reshack. Undid it and the reshack was restored.
Do this have to do with the manual temp scale?
I think I'm gonna leave things as they are since the camera has improved a lot since the factory settings.
Best!
