Hey folks, I'm a long time lurker but first time poster.
I purchased an E4 a few months ago, but prior to purchasing I had come across the ability to hack it, and this thread. I read through the whole thing, finally picked up an E4, used it for awhile, and then decided I wanted to "upgrade it". I read through the thread again (took awhile), located the files I needed, and sat down to start, and got stuck pretty quick. I'm hoping somebody can help.
I have an E4 1.2L, running 2.3.0
Using FlirInstallNet, I tried to put my camera into RNDIS mode, the temporary file didn't seem to work, so I tried the permanent one. I'm in RNDIS mode now, I think, but when I open FlirInstallNet again the IP address is 169.254.199.115, not the expected 192.168.0.2. In network connections there is a connection with the mentioned IP address, and its called FLIR Camera Network Device #2. However, I can't FTP into it, and when I try to run the remove RNDIS FIF file, all I get is a connection timeout error.
Thoughts?
Thanks so much in advance
~Jeff
