So I purchased the camera I mentioned a few post's back. I'm looking for some suggestions of what I might do to diagnose/fix the problem. The owner was nice, said the camera had sat for a while, does not appear he had messed with it at all. The camera is in great condition, except it doesn't start up.
The Camera is a Flir E5 V 1.19.8
What is wrong:
- The camera does nothing when the power button is pushed and while connected to battery.
What I know so far:
- The camera was sitting for an extended period of time
- Battery appears to be fully charged, it was mostly charged when I got it and is now full.
- The screen works but the only thing I am able to get to see is the battery charge/charged screen.
- The usb memory reports as 173mb, there was only a DCIM folder on it with last picture taken 2016.
- When in Flir tools, going to import pictures only showed about 10 photos, but when looking in file explorer there were probably around 200.
What I have tried / What are my thoughts so far:
- I tried to update the firmware, but because the camera fails to start it seems it can not start the firmware upgrade
- I am not sure what the memory should report as, but 173mb seems low to me, I am wondering if this is where the problem is.
- I tried deleting the photos both in explorer and flir tools as I believe I read on here someone being suggested to delete photos when his camera was not working properly.
- The firmware files appear to be loaded onto the "sd card" now, but can't boot to load them.
- I am not sure if there is a way to run the firmware from a computer without booting the device
- I do not know if the battery is dead / malfunctioning even though it seems charged. Not sure if they are okay once charged after a low voltage may have happened.
- Not sure if the camera can normally boot off usb without a battery. That would let me know its not the battery that's the problem because it does not boot just charges.
Any help would be very much appreciated, I have read thru many of the posts looking for troubleshooting suggestions, but have not located anything with the problem I am having. Can not find any other sources of information on the internet except here. The people here seem to be great. I only hope I would be as helpful, understanding, and patient when faced with constant streams of questions about knowledge that has taken years to build, without compensation.
ps. last ditch effort, I could send it back to flir. Trying to leave that as last resort though.
