I used win7 with virtual machine, installed the driver and I could get into the camera by FTP. What a relief.
Updated my E6 camera v2.11 firmware, went OK ->
= CONNECT TO FTP
= CREATING BACKUP DIR backup-20190106053238
= RETR /FlashBFS/system/common_dll.dll
= RETR /FlashFS/system/appcore.d/config.d/conf.cfc
Applying 1 bytes of delta at 000053df
Applying 1 bytes of delta at 000af32f
Applying 1 bytes of delta at 0000042c
Applying 4331 bytes of delta at 0000045c
* stopping application...
* uploading common_dll.dll to /FlashBFS/system/
* failed (error_perm('550 File unavailable (e.g., file not found, no access).'
* attempt 2
* attempt 3
* attempt 4
* uploading conf.cfc to /FlashFS/system/appcore.d/config.d/
* PLEASE HARD-REBOOT DEVICE.
But after reboot the camera IR image was stretched/scrambled.
I restored the backup files, the image is now Ok (to what it used to be)
Is it possible to update an E6 camera with FLIR_E4_2.11.0_hack.zip ?
I think to switch from 160x120 to 320x240 is worth.
Does the menu needs to be updated too ?
Rgds,
Edit : I seek for files regarding resolution improvement and I could not find anything for E6 ... this is bad. :-(
Edit 2 : Menu improvement works, taken files from e5, and renamed all.
