Good news everyone:
Quick notification in advance:
The camera HAS a working manual temperature mode *verified*!
ALPHA AND SEVERELY CRASHING - the attached file is NOT perfect - it should be tried only by advanced users !!!
replace \FlashBFS\system\ui.d\toolbar-config_Z3.xml with the modded one (rename) over FTP and perform a cold cam-reboot - you'll have several additional features (didn't have time to test all the menus - for example "measurement" has some issues and will crash when selecting a cerain menu item)!
BE WARNED: the attached config will cause crash of appcore on bootup once "stuck"
If you'd like to experiment yourself then take a look at the strings of those files:
\FlashBFS\system\ui.d\languages\<file>
\FlashBFS\system\facet_ui_qml.dll
Maybe there's a way to restart facet without cold restart... I also did some documenting on the shell calls - but not ready for release yet.
Could it be that it crashes because you have to activate the measurement first/instead?
Because some are disabled in the E8.cfg file.. (
I already mentioned it a few pages back )
I noticed some of the config strings are disabled, and these are (I have sorted them, they are not in the same spot in the E8.cfg file):
.caps.config.image.sysimg.irMarkers.box.enabled bool false
.caps.config.image.sysimg.visualMarkers.box.enabled bool false
.caps.config.image.sysimg.irMarkers.spot.enabled bool false
.caps.config.image.sysimg.visualMarkers.spot.enabled bool false
.caps.config.image.sysimg.measureFuncs.mcircle.enabled bool false
.caps.config.image.sysimg.measureFuncs.mline.enabled bool false
.caps.config.image.sysimg.measureFuncs.isotherm.dual bool false
