For those who want to realign MSX - there's an easier way to do it without needing to reverse engineer the FLIR file format
You can also use it to add MSX to pictures from cameras without MSX (ie. Therm-App converted images)
What you need:
- Microsoft Word
- FLIR Tools Plus
1. In FLIR Tools, activate the FLIR Tools Plus trial (if you need more time for your trial, there's a painfully obvious way to defeat the 30day limit). Make sure that Word Reporting is activated (press "i" under license options).
2. In Word, open the FLIR Tools+ tab and press "IR Viewer"
3. Right click -> Open and open your Radiometric JPEG. Then, select "Image Fusion"
4. Press "Open Photo" to use a alternative photo or to load your own one for a non-MSX camera. Otherwise, it's obvious from here.
Make sure your alignpoints are spread evenly across the image for the most optimal alignment. (I know mine are not spread out. Do as I say, not as I do.)
5. You can press "Reference Point X" buttons to zoom in.
6. Right-click -> Save As to save a Radiometric JPG with your new alignment data built in. This can be opened in FLIR Tools.
7. Volia! You just aligned your MSX / added MSX to a non-MSX image!
