Hi
Is anyone working on a software upgrade to version 1.19.8 up to 2.3.0 and using HACK?
All I know is (based on personal experience):
1. Updating is possible, increased resolution is maintained. However, they do not operate certain features, symptoms:
- The camera (up) runs longer
- Do not operate (free) extended menu (the meniu settings)
- When you turn on the camera (full restart), it takes about 2 minutes to be able to read and write images to internal memory
- Does not work manually change the scope of termperature.
The problem (probably) is associated with a file conf.cfc and conf.cfg
In older cameras is located file conf.cfg
In the new cameras is conf.cfc file?
I did not get so far no information on the matter.
I would ask that someone presented a sample file conf.cfc (structure)
Feel free to common solve the problem
