@All
SOS SOS SOS!
Okay people, I ask for your urgent help and sympathy!
I was just working with snapshots organizing (removing unnecessary files), when my device halted... after reboot, I saw lots of spatial color noise (much like on un-calibrated sensor), and it did not disappear after calibration, or multiple reboots, or even the battery pull offs.
Have anyone of you experienced the like issue? If so, what could be the problem and how you corrected this?
I personally believe that maybe somehow FS gets damaged so system cannot get access to calibration data of the sensor and hence, uses the default values. Because all other features work perfectly.
Really, people, what do we know about how FS mounts and what it does if it gets corrupted? Is there any 'disk check' or partition recovery procedure we could perform in such the case?
Situations like halts (out memory, appcore crash, reboot without saving etc., error during editing a snapshot, may appear routeenly when using device. So, sooner or later, FS gets corrupted and what then?
Thank you for your support!
UPDATE:
Situation resolved before I have time to panic. But the issue is not gone I think, so the question I addressed to you still there!
I was working with the Charger connected, so the device became quite hot with closed shutter, 53.5C according the web-service temperature log (assuming it had opportunity to add the log!)
How overheating may have resulted in this malfunction?
I just let it to stay still for ten minutes, and the first reboot did well with calibration etc.
Your honorable opinion will be?
