Total Members Voted: 805
0 Members and 19 Guests are viewing this topic.
You could still have it shipped to a trusted U.S. resident and have them forward it to you.
but there is a good chance that a brand new thermal cam with all accessories in unopened box together with receipts will attract enough attention of customs and one will be charged vat which makes whole operation a bit pointless it still is worth a shot if price is main factor
Not known if framerate is changeable but no reason for it to not be baked into the FPGA, especially due to the ITAR issues.The only thing I've seen relating to framerate is the "Allow_30Hz" or similar message in the bootup text, but this may just be a status readout from the FPGA.
Quote from: mikeselectricstuff on November 05, 2013, 05:27:08 pmNot known if framerate is changeable but no reason for it to not be baked into the FPGA, especially due to the ITAR issues.The only thing I've seen relating to framerate is the "Allow_30Hz" or similar message in the bootup text, but this may just be a status readout from the FPGA.The "Is 30 Hz Allowed" message seems to be entirely driven by the "version.hw.det_board.article", "version.hw.mainboard.article" and "version.hw.mainboard.revision" keys. There seem to be several combinations that would result in a "Yes".Of course it might be easier to just patch the binary to make it return "1" all the time ... becasue those values above could be used somewhere else to configure hw differently or something ...
Assuming that FLIR is on to us, how long do you suspect it would take them to patch the hardware such that it can no longer (easily) be hacked? I mean could the next batch be immune? Or does this kind of hardware/software fix take months to finish and re-test etc?
I can't get a value for "version.hw.det_board.article", is that just me?"version.hw.mainboard.article" returns T198283, "version.hw.mainboard.revision" returns 10 (probably 1.0)
Quote from: tnt on November 05, 2013, 03:10:18 pmQuote from: ee.jcesar on November 05, 2013, 02:52:22 pmIs there anyway FLIR can patch this hack? I want to buy one but, unfortunately, not this year... As mentionned earlier ... yes, plenty of ways. Especially for new camera. But even if you updated the fw on a old one there is plenty of things they could do.Would it be un-hackable ? Doubtful, but they could make it really painful and then you'd need motivated people that don't already have an hacked one to get to work on it ... Actually now that I think on it, doing it only for new cam might be a good technique ... I'm sure several people (me for eg) wouldn't spend any time looking at bypassing a new protection scheme if the old bypass kept working on my camera ...Too bad, I can't afford it right now.
Mike quick question for further reference.What methodology did you use to determine whether pin was input or output using pullup/pulldown resistors?I understand the concept but how did you choose the value (strong vs weak?) or what if it was a GPIO (software configured, can be driven, pulled, high z?)Just trying to get some insight for future targets Thank you.
If it remains the same 100% of the time, it's either an input, a voltage supply, or a ground.
Quote from: StevenWhitney on November 05, 2013, 10:35:09 pm If it remains the same 100% of the time, it's either an input, a voltage supply, or a ground. Or an output that you've not yet discovered the purpose of, or missed a brief pulse on, or only chnages under circumstances you've yet to discover. Easy enough to see how it reacts to a pullup/pulldown to be more sure.
But, how do you manage to dare opening quite costly stuff without being feared of failing?
