Poll
275 (28%)
444 (45.2%)
49 (5%)
51 (5.2%)
164 (16.7%)
Total Members Voted: 805
Author Topic: Flir E4 Thermal imaging camera teardown  (Read 3997770 times)
0 Members and 23 Guests are viewing this topic.
Offline krom
« Reply #6275 on: December 27, 2014, 11:09:30 pm »
Note that the biggest sale of the year for the E4 is coming this Monday. Stay tuned.  Could be under $600 each.
Good job on menu mod.  I just need to find a old windows 7 PC to do it.  That FLIRtools software doesn't install on a VM right.
Who/where is this sale happening?
Is it safe to assume that the hack still works on the latest version?
Offline ThermalGuru
« Reply #6276 on: December 27, 2014, 11:38:37 pm »
Keep in mind if you plan to make a purchase and want to use the Flir redemption offer that you need to purchase before Dec 31st.
See: http://www.flir.com/instruments/display/?id=64494
Offline FredB
« Reply #6277 on: December 27, 2014, 11:51:24 pm »
Ok great. 3 spots are also working. It is a sort of variant of spot measurement. It is useful for doing and reading different temperature measurements near each other at the same time. Thank you, Janekivi.  :) You invented a new measurement for Flir.  ;)
Do you also have programmed hot spot and cold spot measurement for the E4? In the measurement box?
I think, that seems very easy for finding the hottest and coldest spot by only pointing around a workplace.  Only the programming seems not so easy because of the big amount of extra sentences in different files, I think. But....we never know. You did already great work.  :clap:
Offline Bud
« Reply #6278 on: December 28, 2014, 12:10:41 am »
Boxing Day present from janekivi, 3-spot measure.
Will keep my E4 warmed up and ready for another one on New Year's Eve
« Last Edit: December 28, 2014, 12:29:08 am by Bud »
Offline tsmith35
« Reply #6279 on: December 28, 2014, 05:10:26 am »
So, do the new hacks of the 2.3.0 FW have capabilities and functionality beyond the hacks available for the 1.22 and prior FW?
Offline joe-c
    • Joe-c.de
« Reply #6280 on: December 28, 2014, 06:59:02 am »
For normal use the most functions seems to work.
But insulation (Isotherm) was not enabled, as far as i know.
And 2 half implemented Measurements (Line and Circle) will also missing. For the normal Camera user surely not important... but this functions will be measured and can readout, but will not be displayed on screen.
But interesting to know is... how much Spots and Boxes are usable?
I have set all to a limit of 5, so I can have 5 spots and 5 Boxes at the same time (well... it is not a really good idea, because it slows down the camera)
and... are difference measurement and ref temp also enabled?
I sadly have much to do last time...
Freeware Thermal Analysis Software: ThermoVision_Joe-C
Some Thermal cameras: Kameras
Offline Bud
« Reply #6281 on: December 28, 2014, 08:10:01 am »
So far the following mods on 2.3.0
resolution
additional palettes
zoom
pip
3-spots measure
workarounds:
manual scale
jpg quality
other:
web interface
battery icons
ftp login without boot (in RNDIS permanent mode, just connect usb cable)
user: anonymous
psw: NcFTP@
Attached is a set of pics before and after resolution mod. Much noise was cured.
EDIT: Also (from earlier in this thread) when battery is charging, pressing Left and Right cursor buttons together will display battery charging progress information.
« Last Edit: December 28, 2014, 08:47:05 am by Bud »
Offline leoibb
« Reply #6282 on: December 28, 2014, 10:31:25 am »
There is,some great effort off you guys far beyond what I understand hats off to you lot. . I'm curious what distance would an e8 read at and does the zoom option zoom the sensor or just the visual screen ?
Offline bookaboo
  • Country: ie
« Reply #6283 on: December 28, 2014, 12:01:43 pm »
The zoom is digital only on the E4-E8 models.
Offline leoibb
« Reply #6284 on: December 28, 2014, 02:56:37 pm »
Ok thanks for that
Offline -jeffB
« Reply #6285 on: December 29, 2014, 05:39:54 am »
It's Monday where I am. Details, please?
Offline michaeliv
« Reply #6286 on: December 29, 2014, 06:40:20 am »
Since it's Monday now for you you're probably out of luck ... this might be US only.
Zoro.com is selling them for 696.50 currently. Use code SAVENOW30.
They do mention something about international shipping ... I'm actually curious about how that works, let us know if you order.
For those that have a Upromise mastercard - you can get an aditional 10% back - making this $625 ...
Or use MrRebates.com for $25 back in cahsback ... if you're into that.
Offline KK
« Reply #6287 on: December 29, 2014, 06:45:45 am »
Zorro.com sale 30% off
Code- SAVENOW30
From 16:00-22:00 UTC 12/29/14
Offline michaeliv
« Reply #6288 on: December 29, 2014, 07:11:40 am »
Code- SAVENOW30
FYI It's Live now... not starting at 16:00 UTC ...
Offline pingo
« Reply #6289 on: December 29, 2014, 07:39:06 am »
Hello. Has there been anything written regarding camera temperature calibration? I see that in cold weather (even above 0°C), reported temperatures are too low by many degrees. Has anyone tried recalibrating it?
Offline The_Raven
« Reply #6290 on: December 29, 2014, 11:01:49 am »
Everything worked fine with a 2.3.0 E4 (resolution, zoom, pip...).  :)
The only thing is that i can not set jpg-quality to 100.
When i log in with telnet and run "rset .image.services.store.quality 100" i get:
rset: failed to contact server
So whats wrong?
Offline bookaboo
  • Country: ie
« Reply #6291 on: December 29, 2014, 11:07:28 am »
Calibration is not straightforward and can only be done with appropriate knowledge and equipment.
What you can and should look at is the settings for reflected temperature and emissivity of what you are looking at (among other things). Thermal cameras are not quite "point and shoot" if you want accurate absolute readings.
Offline joe-c
    • Joe-c.de
« Reply #6292 on: December 29, 2014, 01:48:43 pm »
hey guys...
I improved my software and now it takes 3 seconds to get a full radiometric image from the Camera (Resolution must be 320x240 and USB with RNDIS).
If the image is arrived, it could be analyzed, interpolate, sharpen, stored....
have fun  :-+
Link (or see footer):Thermoviewer_007_release
edit: link now correct
« Last Edit: December 30, 2014, 09:46:13 am by joe-c »
Offline -jeffB
« Reply #6293 on: December 29, 2014, 02:56:59 pm »
Ah, I see. I got mine from Zoro with an earlier 25% coupon (yes, I'm US). It would have been great to save another $50, but not great enough to do a return-and-rebuy, and after the reminders on this thread, I'm not really comfortable doing the hack-and-flip-on-eBay thing.
Offline michaeliv
« Reply #6294 on: December 29, 2014, 03:41:57 pm »
what reminders on this thread prevent you from hacking/flipping on eBay ?
Offline Fraser
« Reply #6295 on: December 29, 2014, 05:22:19 pm »
@michaeliv,
Simple....FLIR may pursue you as you will be a seller of what they perceive as a 'Fake' product. They have done it before. It may sound illogical but that is the route that their legal bods have taken.
To date FLIR have directed their pursuit of such sellers via ebay and via dealers who supplied the camera. They can obtain your home address and details through these means.
At least one person on this forum has 'gone dark' after being directly contacted by FLIR with threats of legal action.
Aurora
« Last Edit: December 29, 2014, 05:26:37 pm by Aurora »
Offline janekivi
  • Country: ee
« Reply #6296 on: December 29, 2014, 08:02:57 pm »
For development there is more data needed...
To seeing how much free space there is on flash, you can add this line to "Camera information":
<ui_model_item type="SettingItem" ID="STORAGE"  label="ID_SETUP_STORAGE"  value="*" nextModel="hiddenServiceSettingsModel"/>I add all interesting stuff if I ever get done something... or crashing
Offline gemrough
« Reply #6297 on: December 29, 2014, 08:11:03 pm »
humm.... is that video I see????
Might pick up another e4 from zoro while it is 30% off. (need the business expense!!)
Offline janekivi
  • Country: ee
« Reply #6298 on: December 29, 2014, 08:22:45 pm »
Ok, this is only picture
Offline gemrough
« Reply #6299 on: December 29, 2014, 09:58:05 pm »
On the one screen it looks like zoom is gone and it has a lightbulb? So only single shot works but it has a film strip? Do you think video recording is available? or is that just when the camera is connected to computer?
