Re. the i3/7, if it is the same as the E4, then the EEPROM is not where you need to be looking.
On the E4, the configuration comes from the conf.cfg file, which is protected by a CRC01 and having the serial number in the file to prevent copying between units.
There are at least a couple of people here with i3/i7 - maybe they could investigate further - I suspect the E4 hack method, or something very similar may well work on the i series
