Maybe it helps to unplug/plug the USB after setting RNDIS mode. I had no problems on Windows 7...
Thanks, I did unplug/plug in USB, and restart a few times, and I managed to FTP the cam now. Cheers!
Continuing the process now....
UPDATE: okay it all seemed to work. Now with better resolution! Many thanks.
A couple of things:
- my IP address was COMPLETELY different (my fault I know).
- I think I was working with an older description as the word "apply" was missing but I see it's now added in: "python apply.py
apply 192.168.0.2"
- the files "Set_RNDIS_temporary.fif" and "Set_RNDIS_permanent.fif" are found in a zip file called "e4hack3c" (this took me a while to find!)
Again, many thanks to all who contributed...
