tsg, you can post the next(third) full-backup for analysis.
Just install the filezilla and the flir-network-driver on your pc,
then go in TIC in the hidden menue(Settings->device-settings->camera-information->10 seconds right and activate in the usb-menue the RNDIS-option)
(later you can do in the same way to reset to the UVC and MSD-option)
If RNDIS is on, connect with filezilla to 192.168.0.2, user: flir, pass: 3vlig and dowload and zip all files.
Then post the zip here und give some information about your cam (you find the data in the camera-information-menue)
all this operations don´t touch any warranty
here is the driver:
http://cdn.cloud.flir.se/swdownload/assets/other/flir_device_drivers.exeI have done the i2c again:
first, i build a little txt for the i2c.exe to scan the bus:
Existing Adresses:
00, 01 only reading, error 1d when writing the start-zero
and
92, 93, AA, AB, AE, AF, D0, D1
\FlashBFS\system>i2c.exe r 00 100
Open I2C device
I2C read command 0 100 returned: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
\FlashBFS\system>i2c.exe r 01 100
Open I2C device
\FlashBFS\system>i2c.exe r 92 100 00
Open I2C device
I2C read command 49 100 returned: 16 CC FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
\FlashBFS\system>i2c.exe r 93 100 00
Open I2C device
I2C read command 49 100 returned: 16 D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
\FlashBFS\system>i2c.exe r AA 100 00
Open I2C device
I2C read command 55 100 returned: 23 1 0 0 FF FF 9E B CD E 38 1 ED 6 16 B 47 6 70 A 7A 0 FF FF 8 2 FD FF 84 8A C0 FC 74 0 C0 15 CE 1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
\FlashBFS\system>i2c.exe r AB 100 00
Open I2C device
I2C read command 55 100 returned: 23 1 0 0 FF FF 9D B C8 E 38 1 ED 6 16 B 47 6 70 A 80 0 FF FF 8 2 FD FF 84 8A C0 FC 74 0 C0 15 E4 1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
\FlashBFS\system>i2c.exe r AE 100 00
Open I2C device
I2C read command 57 100 returned: 46 4C 49 52 20 45 34 0 0 0 0 0 0 0 0 0 0 0 0 0 36 33 39 30 31 2D 30 31 30 31 0 0 0 0 0 0 36 33 39 31 34 37 35 32 0 0 32 30 31 34 2D 30 32 2D 31 33 0 0 30 31 0 0 DE CA 54 31 39 38 32 38 33 0 0 0 32 30 31 33 36 30 31 36 0 0 31 31 0 0 0 0 0 0 0 0 ED 9C FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF A F4 3C 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 46 F4 54 31 39 38 33 30 34 0 0 0 36 33 38 31 33 38 30 38 0 0 30 31 0 0 FF FF FF FF FF FF F2 9F 50 0 3C 0 0 1 0 0 0 0 0 0 0 0 8C 1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0
\FlashBFS\system>i2c.exe r AF 100 00
Open I2C device
\FlashBFS\system>i2c.exe r D0 100 00
Open I2C device
I2C read command 68 100 returned: 16 15 21 4 6 3 14 B3 0 2 0 4 0 30 40 0 10 80 0 0 0 0 98 8 0 14 0 2 0 0 40 10 90 0 0 0 0 80 0 30 0 4 11 0 4 40 0 0 20 0 0 0 0 10 0 0 4 40 4 8 6 21 24 82 16 15 21 4 6 3 14 B3 0 2 0 4 0 30 40 0 10 80 0 0 0 0 98 8 0 14 0 2 0 0 40 10 90 0 0 0 0 80 0 30 0 4 11 0 4 40 0 0 20 0 0 0 0 10 0 0 4 40 4 8 6 21 24 82 16 15 21 4 6 3 14 B3 0 2 0 4 0 30 40 0 10 80 0 0 0 0 98 8 0 14 0 2 0 0 40 10 90 0 0 0 0 80 0 30 0 4 11 0 4 40 0 0 20 0 0 0 0 10 0 0 4 40 4 8 6 21 24 82 16 15 21 4 6 3 14 B3 0 2 0 4 0 30 40 0 10 80 0 0 0 0 98 8 0 14 0 2 0 0 40 10 90 0 0 0 0 80 0 30 0 4 11 0 4 40 0 0 20 0 0 0 0 10 0 0 4 40 4 8 6 21 24 82
\FlashBFS\system>i2c.exe r D1 100 00
Open I2C device
I2C read command 68 100 returned: 25 15 21 4 6 3 14 B3 0 2 0 4 0 30 40 0 10 80 0 0 0 0 98 8 0 14 0 2 0 0 40 10 90 0 0 0 0 80 0 30 0 4 11 0 4 40 0 0 20 0 0 0 0 10 0 0 4 40 4 8 6 21 24 82 25 15 21 4 6 3 14 B3 0 2 0 4 0 30 40 0 10 80 0 0 0 0 98 8 0 14 0 2 0 0 40 10 90 0 0 0 0 80 0 30 0 4 11 0 4 40 0 0 20 0 0 0 0 10 0 0 4 40 4 8 6 21 24 82 25 15 21 4 6 3 14 B3 0 2 0 4 0 30 40 0 10 80 0 0 0 0 98 8 0 14 0 2 0 0 40 10 90 0 0 0 0 80 0 30 0 4 11 0 4 40 0 0 20 0 0 0 0 10 0 0 4 40 4 8 6 21 24 82 25 15 21 4 6 3 14 B3 0 2 0 4 0 30 40 0 10 80 0 0 0 0 98 8 0 14 0 2 0 0 40 10 90 0 0 0 0 80 0 30 0 4 11 0 4 40 0 0 20 0 0 0 0 10 0 0 4 40 4 8 6 21 24 82
Maybe is the xor-key in it anywhere?
