People. THANK YOUUUU!!!!!!!!
I've updated my cam in resolution and in the menu. Converted it from a cool thermometer into an amazing camera!!
The difference is BRUTAL!. Infinite thanks for sharing the info.
I used the Filezila method, really straightforward. I updated the resolution and menu at the same time.
_____________________________
All newbies (like me) I recommend the Filezila method.
Tha txt of the hack, when says all stuff must go in caps, it does not reffer to the generated key tu to the first part of the string : # CRC01
Dont forget to rename the E8.cfg to e8cfg
After setting the usb mode for connecting via FTP don't forget to switch back otherwise no way to see the images and lot of tension like did I screw it up?!?!!?
While doing the backup some files did not get copied, probably this is normal, don't remember reading anything on this. It took my 1-2 hours, rereading everything... better safe than sorry
Probably it is documented in teh manual but did not read yet, if you press the photo button continuously it take photos continuously, GREAT feature to stick the cam on a multicopter or plane. ( with a zip or simply duck tape. or for doing timelapses...
I'll be posting images in the other thread...
infinite thanks!!!
