@andy1read
This is the reason that I am so grateful for the new manual mode that Taucher introduced for us.
I often work with temperature spans of 2 or 4 Degees Celsius when using an industrial TIC, I found that the E4 was regularly setting a wide span of 10 Degrees or greater, no matter what the target FOV temperature range (as you have found). I have the feeling that FLIR set the Ex auto ranging to provide the 'prettiest', rather than most useful, picture on the users screen. There can be a large difference between what looks like a 'nice picture' with low noise and soft transitions, and a true thermographic measurement image where thermal resolution is important, and noise less so. My PM695 produces quite a noisy image at 2 Degrees C Span but it is the dogs dodads for spotting tempertaure differential in these small spans. When using the E4 I use Manual mode often and prefer that mode when monitoring PCB's etc.
