Author Topic: Freeware Software for Thermal Analysis: Thermovision_JoeC  (Read 533596 times)
Offline m.abdelwanis
  • Country: eg
Re: Freeware Software for Thermal Analysis: Thermovision_JoeC
« Reply #375 on: November 04, 2023, 07:37:18 pm »
Will or does it support Fluke Mobile Thermal camera TC01A ?
Best Regards
Mo
Offline joe-cTopic starter
    • Joe-c.de
« Reply #376 on: November 05, 2023, 01:49:05 pm »
Version 1.11 is being flagged by Google Drive as having a virus, and will not allow downloading. Is there a way around this?
Is this issue still existing? I looked at google drive and the package looks normal.
It’s known some Scanners detect here something. The only way to lower the risk of detection is remove functionality.
I have here a description in German about Virus Errors:
https://joe-c.de/software/thermovision/viruserror
Not yet.
I skipped Fluke Cameras because they are rare, expensive and have much noise compared to many other devices.
… maybe later, if I have time to look at there format.
Hi All,
It was really long since last version.
Download: https://drive.google.com/file/d/18AB76YUSdJvnYkBZ_kwpw0lYpXQ-Cqgm/view?usp=sharing
After reading some Licenses I decide to choose MIT now. This Software is public OpenScource now.
There still some open tasks like Infiray Camera support.
Link to source: https://github.com/JoeC-de/ThermoVision_JoeC
I have here a German description about the new Version. I see some Browsers have now an internal translation function. Hope it works:
https://joe-c.de/software/thermovision/versionen/1-12-0-0
(I had to rebuild my website after some issues with updates from my webhoster)
Here the release notes in english:
ThermalSequence:
refactured Thermal Sequcence. Allow to record frames to single container file.
improved aquisition from Flir .SEQ files. Create sequence from Batch Processing.
IrDecoder:
New subwindow with improved preview and more file analysis capabilitys.
Its usable as target in Imagebrowser. Settings are stored in .TCS file
File drop panel:
If not disabled in Settings, there is a new Panel for file drop to select the target of the file. Additional infos about the file to drop was shown in panel.
Draw Raw Mode:
Implement additionalimage processing from Raw with fixed Color array. Allow higher FPS. Histogram also can be calculated from raw frames.
BatchProcessing:
Moved to own Usercontrol. Has more functions and a statistic.
Imagebrowser:
image sort mode selectable. add mouse selection rectangle. Mouse double click additional trigger "search images..."
Add Imgeformat support:
-add device DJI Mavic 2 Drohne read frame
-add device Nec/Keysight read frame
-improve for Bosch GTC 600 (and new formular for GTC 400)
-improve IrDecoder for Optris CSV (temperature map)
-improve optris .tiff from App
-add XarySensor device (only .XRG files now, its a own special format)
Add Camera support:
-add device optris Pi Camera
common changes:
-TempMath improve OverFlow/UnderFlow logging
-add DOG (diff of gausian) Filter
-CC Flir: add exclude FTP folder (like "StorageCard")
-add Search box to File Editor (FLIR CRC) and the Editor is no more hidden
-add parameter "-LOAD_TCS="
-show raw in "local parameter"
-16bit Tif export add "Temp Slope/Offset" mode
-AreaRange add support for search "min range"
-add variable palette color scale depth
-Label with replaced pixel on Live Temp/raw remove death pixel
-escape to cancel set measurement (skip drawing)
-change "ON/OFF" to Arrow and text color to light blue
-bugfix: open TV with stored Area, image offset adjusted
-add "open folder" link to status bar mouse menu
-add setting DevMode
-seek thermal initialisation with Operation=0
-2Point cal can use 2 MeasurePoints as input
-spot show raw replace value, not label
-bugfix: zoom south/east -> index out of range
-add driver specific temperature conversion
Freeware Thermal Analysis Software: ThermoVision_Joe-C
Some Thermal cameras: Kameras
The following users thanked this post: mk_
