Author Topic: FLIR C5: Can I Use a Thermal Module from FLIR Scout TK? 🚀  (Read 1328 times)
Offline w0nk1Topic starter
« on: April 09, 2024, 04:59:49 pm »
Hi guys,
I've got a question that might be interesting. Can you swap the thermal imaging module from a FLIR C5 with one from a FLIR Scout TK? I'm asking because the C5's module is broken, and after switching it with the Scout TK's, the C5 turned on okay, but the measurements are all over the place. Is there another way to replace it, or will it always give wrong numbers?
Thanks!
Cheers,
Markus
Offline Fraser
Re: FLIR C5: Can I Use a Thermal Module from FLIR Scout TK? 🚀
« Reply #1 on: April 09, 2024, 06:55:45 pm »
Lepton 3.5 Radiometric (C5) Vs Lepton 3.0 NON-Radiometric (TK)
Fraser
