Author Topic: Ultramax  (Read 1593 times)
Offline eg14Topic starter
Ultramax
« on: October 25, 2017, 03:08:02 pm »
Can someone please share some FLIR jpegs with embedded Ultramax data?
Thanks
Offline Bud
Re: Ultramax
« Reply #2 on: October 25, 2017, 03:12:57 pm »
Unfortunately none of those images were taken with the ultramax feature enabled.
Offline Bud
Re: Ultramax
« Reply #3 on: October 25, 2017, 03:54:26 pm »
Are you looking specifically for a file in Flir format ? 'Cuase all it does is takes several of regular images in a burst as explained in a Flir user manual. Then processing is done in Flir Tools desktop software.
UltraMax is an image enhancement feature that will increase the image resolution and lower the noise, making small objects easier to see and measure. An UltraMax image is twice as wide and high as an ordinary image. When an UltraMax image is captured by the camera, several ordinary images are saved in the same file. Capturing all the images can take up to one second.
Re: Ultramax
« Reply #4 on: October 25, 2017, 04:01:04 pm »
Yes, I would like one of those files, so I can do the processing myself in FLIR Tools and see the change from the single image to the "super resolution" image.
Offline Bud
Re: Ultramax
« Reply #5 on: October 25, 2017, 04:34:50 pm »
I see. Why don't you ask OP in that thread for one, he actually asked if someone wants anything specific.
Offline tomas123
Re: Ultramax
« Reply #6 on: October 26, 2017, 11:41:43 pm »
last year I got an ultramax image from a Flir T440 and I extracted the 16 frames
http://u88.n24.queensu.ca/exiftool/forum/index.php/topic,6763.msg33943.html#msg33943
Unfortunately I deleted the image. As far as I can remember, the file size was really big, therefore all web images a compressed  ;)
« Last Edit: October 26, 2017, 11:49:34 pm by tomas123 »
