Author Topic: Flir One IOS App with full Lepton sensor resolution 160x120  (Read 10754 times)
Offline RTouris
  • Country: gr
Re: Flir One IOS App with full Lepton sensor resolution 160x120
« Reply #25 on: February 11, 2017, 11:55:13 am »
Glad you liked them Georg. Sure thing on using them, I can't see any reason you couldn't, I'm all go ahead from my part.
Offline gansgar
« Reply #26 on: February 11, 2017, 12:35:45 pm »
Thank you for your quick reply. I'll add them in the next update.
Sent from my SM-N910F using Tapatalk
Offline Howardlong
« Reply #27 on: February 13, 2017, 06:59:51 am »
Wow, I had not realised that the flir app has deliberately crippled the sensor's resolution by simple cropping.
Very well done!
Is there a possibility of an option to allow MSX offset for close in work?
Offline gansgar
« Reply #28 on: February 13, 2017, 07:04:11 am »
Very well done!
Thank you. If you want, you can give me rating on the AppStore.
Yes. Just drag and drop on the thermal image, as long as you've have activated MSX.
« Last Edit: February 13, 2017, 07:10:44 am by gansgar »
Offline RTouris
  • Country: gr
« Reply #29 on: February 13, 2017, 07:10:23 am »
Indeed having MSX enabled you may just drag on the superimposed image and that adjusts the offset to the underlying thermal base to a given extend. I think the offset is good to about 3-4cm distance to the object.
Any hints as to what we might expect from the update? It's all down to priorities, but I suppose landscape orientation of elements could come in handy (as in a welcome ironing of the UI), as well as some sort of panorama mode as per the original Flir app..?
[edit: not that I'm not fond of the original icon, just thought I'd propose something along the lines of the original and spice it up a bit ;) ]
« Last Edit: February 13, 2017, 10:09:44 am by RTouris »
