Author Topic: Thermal imaging to catch cycling cheats  (Read 2190 times)
Offline DenzilPenberthyTopic starter
« on: April 20, 2016, 12:13:14 pm »
It seem to be becoming more clear that secret hidden motors are a thing which is happening in pro cycling. Interesting use here of TI to spot suspicious hot areas on bike frames during races...
http://fittish.deadspin.com/secret-thermal-camera-footage-allegedly-shows-seven-pro-1771492666
Offline CatalinaWOW
Re: Thermal imaging to catch cycling cheats
« Reply #1 on: April 20, 2016, 02:53:10 pm »
Seems like it would be really easy to institute random x-rays of equipment.  Combine that with an appropriate penalty (one year ban from racing for example), and the problem should go away.  Cycling is a strange sport.  Cheating seems widespread, and enforcement somewhat haphazard and arbitrary.
Offline charlespax
    • Pax Instruments
« Reply #2 on: April 30, 2016, 10:23:57 am »
I wonder if the heat output would be as bad if they were using super caps.
« Reply #3 on: April 30, 2016, 11:19:56 am »
So just as crooked as soccer then, but the cheating is more hidden from view. Seems like they should simply have a few ex TSA luggage scanners at each event for all bikes to go through, right after the end, with the monitor output on public display for everyone to see. Or expect to see a lot of reporters at the finish line with thermal cameras as part of the camera gear.
