E30
2.23.14
49001-1801
So my new to me E30 arrived. All works great. I played with RNDIS, WinSCP and backed up all the files on the unit. I understand there are a couple ways to upgrade these and have read nearly every post, but still have a couple questions.
I found the EZCCRC01 program and ran it with my serial number. It created the e8.cfg file and I believe I can either use WinSCP or the FlirNetInstall.exe to "run" the file (once renamed to .fif, yes? Will this e8.cfg file work on the E30? I have seen some posts referencing the name change in a config file (e30 to e60) so not sure about that part.
Does the e8.cfg file as created by EZCRC01 program enable all the gadgets such as wifi, bluetooth, etc by default? Another thread mentioned just doing minor edits to the original config (noise generator to 0, resolution to 320, zoom to whatever you choose) so just hoping to do this once and not play with it afterwards.
Thanks for your patience.
