Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Thermal Imaging
Infray P2 Pro - 3D printed insert for SD card case
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Infray P2 Pro - 3D printed insert for SD card case (Read 1165 times)
mikeselectricstuff
Super Contributor
Country:
on:
July 21, 2023, 03:07:31 pm »
I originally bodged an insert to fit the P2 into this very nice JJC memory card case.
I've now done a 3D printable soft TPU insert for this.
You could probably do one in a hard plastic using flexure spring inserts for grip but I was already looking for something to try TPU
The case is very nice, far better than anything you could 3D print.
Available here
https://www.printables.com/model/532567-p2insert
Last Edit: July 21, 2023, 03:11:57 pm by mikeselectricstuff
Logged
Youtube channel
:Taking wierd stuff apart. Very apart.
Mike's Electric Stuff
: High voltage, vintage electronics etc.
Day Job
: Mostly LEDs
Fraser
Fraser
Super Contributor
Country:
Re: Infray P2 Pro - 3D printed insert for SD card case
Reply #1 on:
July 21, 2023, 04:42:13 pm »
Excellent work. Thank you Mike.
I have yet to try printing TPU but this will be on the list to do if I get into that material.
Fraser
Logged
If I have helped you please consider a donation :
https://gofund.me/c86b0a2c
cynfab
Regular Contributor
Country:
Reply #2 on:
July 22, 2023, 05:30:45 pm »
Fraser, Mike
Thanks for the great reviews, teardown and discussion of the P2Pro. I got myself one and am very happy with it.
I saw the great idea that Mike had regarding the JJC uSD card case, so I got one of those too. Unfortunately I really didn't like putting the cable inside on top of the P2Pro's window. I also didn't want to carve up the original foam inserts.
After a few hours with OpenSCAD and several meters of PLA, I now have an insert the fits inside the JJC case after removing the uSD card inserts. A bit of isopropyl alcohol was used to help remove the inserts and seperate the two parts, cut away 1/4 of the result and glue it back into the top.
Now the P2Pro, its Macro lens and a few USB C adapters all fit safely inside the case, the cable does not.
Attached is the OpenSCAD source. Not pretty or elegant as some OpenSCAD projects tend to be,
...ugly but effective...
OpenSCAD:
https://openscad.org/downloads.html
uSD card case:
https://www.amazon.com/dp/B0B76BDXN8?psc=1&ref=ppx_yo2ov_dt_b_product_details
USB C female to USB A male (USB 2 high speed only):
https://www.amazon.com/dp/B07LF72431?psc=1&ref=ppx_yo2ov_dt_b_product_details
USB C female to USB C male 180 degree:
https://www.amazon.com/dp/B09ZHFWZR9?psc=1&ref=ppx_yo2ov_dt_b_product_details
USB C female to uUSB male:
https://www.amazon.com/dp/B07GH5KJH2?psc=1&ref=ppx_yo2ov_dt_b_product_details
Last Edit: July 22, 2023, 05:34:44 pm by cynfab
Logged
Fraser
Fraser
Super Contributor
Country:
Reply #3 on:
July 22, 2023, 07:41:48 pm »
Cynfab,
Nice work. Thank you for sharing.That little P2 Pro is certainly a useful little thermal camera
Fraser
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Thermal Imaging
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
