Author Topic: differances in this two units  (Read 1584 times)
Offline bowhunter-57Topic starter
« on: February 07, 2017, 11:42:59 pm »
need help in deciding on this two units,which one is better, Thermo-App vs TE-Q1 Pro
Offline frenky
  • Country: si
    • Frenki.net
Re: differances in this two units
« Reply #1 on: February 09, 2017, 11:35:58 am »
Both are very good thermal modules.
It makes no sense to buy  TE-Q1 Pro because basic TE-Q1 can measure 150*C with no problem...
So comparison should be: Therm-App (19mm f/1.1) vs TE-Q1 Plus (13mm f/1.0)
With Therm-App you will get narrower field of view which is better for outdoors while TE-Q1 Plus has wider lens which are better for close range inspection...
Price is a factor too. Therm-App is 1000$ while TE-Q1 Plus is 600$ (if you can get it directly from manufacturer i3system).
« Reply #2 on: February 09, 2017, 08:43:38 pm »
Thank you for the reply.
