Hello,
I've successfully hacked a Flir E4 camera (E4 1.2L with fw 2.3.0). However, when I try to revert the RNDIS mode using the FlirInstallNet and the "Remove_RNDIS_Permament.fif", I can't have access to the USB storage drive. I can see an USB logo on the display, but with my Win7 pc the device is recognized as a Network adapter, while in my collegue's PC with Win10 it is seen as a USB Com port.
Should I do something else to put the device in USB mode? At the moment, the only way to see the images is using Filezilla to browse into the images folder.
