Author Topic: Brand New SEEK Thermal Compact PRO - slipped from my fingers - Gone  (Read 8468 times)
Offline eKretz
Re: Brand New SEEK Thermal Compact PRO - slipped from my fingers - Gone
« Reply #25 on: July 17, 2018, 02:21:15 pm »
Doesn't matter how heavy the item dropped is at all. The important thing is how hard the impact - or more properly I suppose,
how rapid the deceleration - is. That is dependent on the mass of the components separately, not together - and how quickly they are moving and how fast they come to a stop. If the force exceeds the ability of the solder joint or joints to hold the component,  it will come right loose. Tiny components have tiny joints, and the force it takes to break them loose is dependent on surface area of the joint.  It really doesn't take a whole lot to break most of them loose.
Very small lightweight components (such as surface mount resistors) won't feel too many Newtons of force from a simple 5 foot drop. Larger ones will feel more force, but they also have bigger solder pads they are soldered too, so more solder, so an overall stronger joint.
Yes,  that's right.  But the part you're leaving out: how many products have we all opened only to find poorly made solder joints? Think those will hold vs. ANY kind of force?
Not sure how much stuff you've worked on,  but after tearing down and repairing probably thousands of devices,  I have dropped a few.  And I have definitely seen plenty of surface mount components pop loose and disappear when items are dropped, even ultra-tiny ones.   Doesn't happen every time,  but it happens.
« Last Edit: July 17, 2018, 03:37:08 pm by eKretz »
Offline Ben321
« Reply #26 on: July 17, 2018, 11:46:32 pm »
Maybe the newer cases were magnesium, but older ones were plastic
Its a video from 2 years ago Aug. 2016
Unlike other cameras you may have tested, Seek Compact Pro thermal imaging camera is extremely light weight. It is small, and its case is made entirely of plastic.
How old do you think the Seek Compact PRO is?
But even the standard old Seek, and not the pro-version your refering to as plastic and that there should have been a pro-version even earlier with plastic.. here is a video from 2014 .. A standard Seek as it is before any Pro version, also magnesium casing.  https://youtu.be/8Cr8oZck5m8?t=10m
I think I got mine back in 2015. It makes a non-metalic plastic-like sound when you tap on its case with your fingernail, and it is very light weight, just like plastic.
Offline eKretz
« Reply #27 on: July 18, 2018, 03:12:13 am »
Not sure what the case is made of,  but the density of magnesium is not much more than that of ABS plastic, so weight won't tell you much. Sound isn't a good indicator either on very thin walls.
