Author Topic: Flir E40 (screen problem)  (Read 1512 times)
Offline walyynowTopic starter
« on: August 02, 2018, 01:32:16 am »
I have FLIR E40 , I have a problem with lcd. The screen is not displayed (white image), look at the pic.
When I connect camera to computer by usb (or by video cabel to tv), I can see image, I can use touchscreen on camera.
I thing LCD is weak. Do You know guys, where can I bought, lcd for this camera? Is it possible?
Offline Chanc3
Re: Flir E40 (screen problem)
« Reply #1 on: August 02, 2018, 07:02:22 am »
@Fraser should be your guy for this, but ideally you'd need to take the camera apart and get a model number from screen. You should then be able to find a replacement.
Offline eKretz
« Reply #2 on: August 02, 2018, 10:54:17 am »
I don't have part numbers but I have had mine apart. It's a 3.5" 320*240 resistive touchscreen. It might be a good idea to take the camera apart and first try reseating the LCD ribbon cables. One may be making poor contact.
« Last Edit: August 02, 2018, 11:01:37 am by eKretz »
