Author Topic: Seek Thermal Pro IOS edition valid on Android OS thrue basic Adapters?  (Read 15125 times)
Offline enderffx
Well, i bit the bullet and bought a Compact Pro FF with Lightning Plug.
I was able to mod the Lightning to microUSB as decribed, THANK YOU!
The ID chip got horribly hot, i simply unsoldered it and its working fine now without hot spots :-)
Thanks!!!
P.S: USB-C Adapter next, already tried but failed, although moving the resistor for CC from +5 to GND its not working as OTG, any idea?
Offline enderffx
Well, pretty much talking to myself here, nevertheless, maybe its of interest to someone later.
Here are USB id's of 3 different Seek:
Seek Compact UW-AAA micro USB:      PIR206/iAP      0x289d 0x0010
Seek Compact Pro FF LQ-AAAX Lightning:   PIR324/iAP      0x289d 0x0011
Seek Compact Pro FF UQ-AAAX micro USB:   PIR234/-         0x289d 0x0011
Offline vidmo
Re: Seek Thermal Pro IOS edition valid on Android OS thrue basic Adapters?
« Reply #27 on: September 23, 2021, 09:08:59 am »
Hi all!
I recently switched from Android to iOS. is there a way to use Seek Compact micro USB version with iPhone with some adapter?
Offline Fraser
« Reply #28 on: September 23, 2021, 10:34:31 am »
Unfortunately this is not possible as the camera needs to be fitted with the Apple ID chip that is not present in the non iOS versions. You could try to course a faulty Seek iOS version and transplant the required cable, Apple ID chip and connector assembly into your working camera unit.
« Last Edit: September 23, 2021, 10:51:42 am by Fraser »
Offline lcfvrn
  • Country: ua
« Reply #29 on: November 03, 2021, 02:19:50 pm »
Hi!
I found several adapters which allow to connect lighting based headphones to android phone.
Will Seek Thermal work with such adapters?
From ugeen - https://aliexpress.com/item/1005003086720291.html
from aniker - https://www.amazon.com/Anker-USB-C-Lightning-Audio-Adapter/dp/B07R6MKJZH
from magnotek - https://www.amazon.com/Mangotek-Lightning-Certified-Headphone-Connector/dp/B0936NK2WT/
« Last Edit: November 03, 2021, 03:16:19 pm by lcfvrn »
Offline JakeMont
« Reply #31 on: February 18, 2023, 10:04:02 pm »
I just successfully adapted my iOS (lightning) Seek Thermal to usb-micro.
Thanks to tonykids for the directions.
I used one of these lighting female to male usb-micro adapters: https://www.amazon.com/dp/B08RHGS3NB
I used a dremel tool with cutting disk to slice and remove the metal coating, then carefully cut and peeled the soft plastic liner.
The pin configuration is exactly the same as in LarryR's post, so I soldered the same as shown there.
I have only basic skills, so I'm shocked that it worked, but I must have gotten lucky with the soldering iron.
It seems to work fine on my old Android USB-micro tablet.
Next step, I hope to get a USB-micro to USB-C adapter and see if I can plug it into my USB-C android tablet.
Offline JakeMont
« Reply #32 on: February 24, 2023, 01:23:19 am »
Quick Update. I have now managed to get my iOS (lightning) Seek Thermal to work on my USB-C tablet.
As described earlier, I created a lightning to USB-Micro adapter as described by tonykids. I then purchased a USB-Micro to USB-C adapter that specifically supported USB OTG. This one: https://www.amazon.com/dp/B01I0ZAJXO. By chaining them together my Seek now works on my USB-C Android tablet!
Thanks All.
