Author Topic: [NEED HELP] Hikmicro B2L just died on me  (Read 1491 times)
Offline glancenTopic starter
  • Country: jp
« on: February 12, 2023, 12:49:07 am »
Hello guys.
First time to post my awful experience.
The firmware is the latest (Firmware_B2L_V5.5.15_220509)
As you can see the link below, when it powers on, after only 5 sec it just go freeze and dies.
Pressing power button to restart doesn't solve the problem and it completely go brick.
https://youtube.com/shorts/JoK44L6VJm8?feature=share
Is there any means to hard reset?
Since it doesn't show the menu bars nor I can reach on the menu or connect to Hikmicro viewer app, I don't have any means to update or revert firmware in normal way :(
I did a quick search but I couldn't find anyone has similar experience..
Maybe I have to tear down and connect UART to do hard reset? I see following astonishing work by Fraser and if it is only thing to do I am up for it.
https://www.eevblog.com/forum/thermal-imaging/hikvision-ds-2tp31-series-thermal-camera-teardown-307840/msg3942805/#msg3942805
Offline markb1980
  • Country: cz
Re: [NEED HELP] Hikmicro B2L just died on me
« Reply #1 on: February 12, 2023, 10:45:39 pm »
Easiest Fix is RMA the camera and get a new one. That seems to be a known bug.
Why would you want to void the warranty? It's a new camera - send it back to the seller and request a fix or new one.
« Last Edit: February 12, 2023, 10:50:17 pm by markb1980 »
Pentester, Digital forensics examiner, Data recovery technitian, Author for various books
Learn thermal imaging: https://www.amazon.com/dp/B0B5KXF41Q/ | https://www.facebook.com/groups/1816479168568552 | https://thermal-image-samples.com/thermal-pixel-peeping/
  • Country: jp
« Reply #2 on: February 13, 2023, 06:15:30 am »
Thank you for your reply.
I thought it would be the firmware problem and any of other device would break down also.
The bug is after I update to the latest firmware(V5.5.15_220509 from V5.5.14 210929), before update there wasn't any problem.
After update, when I use only with lower thermal range, it works fine. The symptom occurred when I switch to higher temp range (100c-500c?) it just frozen then it became just like this ever since..
Regarding RMA unfortunately it was from eBAY and there wasn't any purchase receipt / warranty paper...
Offline markb1980
  • Country: cz
« Reply #3 on: February 13, 2023, 07:33:57 am »
Seems like the update damaged something. They had lately issues with updates.
Contact the Hikmicro support.
Offline markb1980
  • Country: cz
« Reply #4 on: February 13, 2023, 12:52:51 pm »
I have asked my contact in Hikmicro and they are working on a solution. Maybe I will get a link for you a little later.
  • Country: jp
« Reply #5 on: February 15, 2023, 02:08:01 pm »
Thank you so much, that is a great relief for me!
I hope I can unbrick this thing because it was working so well for the price..
Offline markb1980
  • Country: cz
  • Country: jp
« Reply #7 on: February 22, 2023, 12:44:35 pm »
Hi markb1980
Thank you for the link. I am surprised they could update the firmware that quickly.
Unfortunately, It is too late for me because the thingy is, whenever I start the device, it goes freeze in 5sec after start up without showing any menu (nor I can access the menu like the video I post).
Therefore having new digicam.dav in the root folder does not trigger the automatically update (it goes brick before that..)
Could you ask your contact in Hikmicro about my situation? I wish there would be any hard kill switch with safe mode start, or hardwire the firmware from the beginning etc..
Thank you again for your trouble! I just hope I could unbrick this device anytime soon...
Offline markb1980
  • Country: cz
« Reply #8 on: February 22, 2023, 02:31:50 pm »
Usually that works because they flash the firmware before booting as far as I know...
Try contacting the support yourself. You can also join my FB-goup. There are 2-3 folks from Hikmicro.
