I haven't heard from them since november when they said that international release date will be in december...They were suppose to release it in Q3, but I guess that will be Q3 in 2016. Edit: And the only change on the website in the last 3 weeks is this page with android app user manual which you can't download...http://www.i3-thermalexpert.com/support/android-app
@schlafli:Did you get the i3 module? If yes, what is the first impression?
We have started to sell the product on Nov. 2015 in Korea, and Dec. 2015 internationally.If you have any inquiries against our product, please ask us through the below e-mail.E-mail: thermal_expert@i3system.com
That's really nice, what is the approximate frame rate? does it stutter
Balls. How do I get one?
Did they ask you to do a direct bank transfer? Mine will have to travel all the way to the US, so i might not get it as fast as you did.
Although, I see it's giving a reading of 303 C when it's specified max temp is 150C. This could be like the Therm-App - it'll display higher temperatures but the further you go from the calibrated maximum (150C), it begins to get wildly inaccurate. It would be much better if they displayed like a ~ symbol or something that lets you know it's out of the calibrated range.
I'm attempting to do the USForex version of what you used, am I correct to assume they are receiving the money in Korean WOT?
Ooooo are those exposed test pads I see??
Array format : 384 x 288Pixel Pitch : 17 um NETD : < 50mKWavelength band : 8~ 14 um
Dimensions: 10.5 x 11.7 x 6.4 mmSpectral range Longwave infrared, 8 um to 14 umArray format 160 × 120, progressive scanPixel size 12 umThermal sensitivity <50 mK
Dimensions: 8.5 x 11.7 x 5.6 mmSpectral range Longwave infrared, 8 um to 14 umArray format 80 × 60, progressive scanPixel size 17 umThermal sensitivity <50 mK (0.050° C)
