Author Topic: FLIR E40 Hack Help S/N:645XXXXXX F/W: 4.11.0  (Read 6013 times)
Offline xbnipxTopic starter
« on: September 04, 2016, 01:26:34 am »
Hi Guys,
I am trying to upgrade the resolution to 320 x 240 However when i do it i lose a lot of the UI components such as Temp and MSX etc.
Here are the steps i did:
1) Backed up FlashFS
2) Copied the config.cfg from FlashFS/system/appcore.d/config.d
3) Deleted CRC01 line leaving one line after S/N
4) generated new CRC using E30_hack files crc01.exe
5) uploaded back to camera overwriting file
6) Remove battery reset camera
NOTE: In FlashFS/system/appcore.d/config.d
There are two files conf.cfg and ui_conf.cfg
# Generated at 2014-06-03 15:18:54
.caps entry
.caps.config entry
.caps.config.name text "app E40"
.caps.config.revision text "1.2"
.caps.config.segment text "handheld"
.caps.config.direction entry
.caps.config.direction.sensorAccel entry
.caps.config.direction.sensorAccel.enabled bool true
.caps.config.direction.compass entry
.caps.config.direction.compass.enabled bool false
.caps.config.direction.lcdAccel entry
.caps.config.direction.lcdAccel.enabled bool true
.caps.config.image entry
.caps.config.image.framegrab entry
.caps.config.image.framegrab.fusion entry
.caps.config.image.framegrab.fusion.enabled bool true
.caps.config.image.framegrab.fusion.pip entry
.caps.config.image.framegrab.fusion.pip.enabled bool true
.caps.config.image.framegrab.fusion.hcf entry
.caps.config.image.framegrab.fusion.hcf.enabled bool true
.caps.config.image.sensor entry
.caps.config.image.sensor.enabled bool true
.caps.config.image.services entry
.caps.config.image.services.store entry
.caps.config.image.services.store.enabled bool true
.caps.config.image.services.store.radiometric entry
.caps.config.image.services.store.radiometric.enabled bool true
.caps.config.image.services.store.incompatible entry
.caps.config.image.services.store.incompatible.enabled bool false
.caps.config.image.services.store.incompatible.level int32 0
.caps.config.image.settings entry
.caps.config.image.settings.enabled bool true
.caps.config.image.settings.downsample bool true
.caps.config.image.settings.resIR int32 160
.caps.config.image.sysimg entry
.caps.config.image.sysimg.alarms entry
.caps.config.image.sysimg.alarms.enabled bool true
.caps.config.image.sysimg.alarms.measfunc entry
.caps.config.image.sysimg.alarms.measfunc.enabled bool true
.caps.config.image.sysimg.alarms.measfunc.maxCount int32 3
.caps.config.image.sysimg.alarms.humidity entry
.caps.config.image.sysimg.alarms.humidity.enabled bool false
.caps.config.image.sysimg.alarms.humidity.maxCount int32 1
.caps.config.image.sysimg.alarms.insulation entry
.caps.config.image.sysimg.alarms.insulation.enabled bool false
.caps.config.image.sysimg.alarms.insulation.maxCount int32 1
.caps.config.image.sysimg.irMarkers entry
.caps.config.image.sysimg.irMarkers.enabled bool false
.caps.config.image.sysimg.irMarkers.spot entry
.caps.config.image.sysimg.irMarkers.spot.enabled bool false
.caps.config.image.sysimg.irMarkers.spot.maxCount int32 0
.caps.config.image.sysimg.irMarkers.arrow entry
.caps.config.image.sysimg.irMarkers.arrow.enabled bool true
.caps.config.image.sysimg.irMarkers.arrow.maxCount int32 0
.caps.config.image.sysimg.irMarkers.box entry
.caps.config.image.sysimg.irMarkers.box.enabled bool false
.caps.config.image.sysimg.irMarkers.box.maxCount int32 0
.caps.config.image.sysimg.measureFuncs entry
.caps.config.image.sysimg.measureFuncs.enabled bool true
.caps.config.image.sysimg.measureFuncs.diff entry
.caps.config.image.sysimg.measureFuncs.diff.enabled bool true
.caps.config.image.sysimg.measureFuncs.diff.maxCount int32 1
.caps.config.image.sysimg.measureFuncs.diff.calcMask int32 65526
.caps.config.image.sysimg.measureFuncs.isotherm entry
.caps.config.image.sysimg.measureFuncs.isotherm.enabled bool true
.caps.config.image.sysimg.measureFuncs.isotherm.calcMask int32 20
.caps.config.image.sysimg.measureFuncs.isotherm.dual bool false
.caps.config.image.sysimg.measureFuncs.isotherm.fixScale bool false
.caps.config.image.sysimg.measureFuncs.isotherm.interval bool true
.caps.config.image.sysimg.measureFuncs.isotherm.invInterval bool false
.caps.config.image.sysimg.measureFuncs.isotherm.maxCount int32 1
.caps.config.image.sysimg.measureFuncs.mbox entry
.caps.config.image.sysimg.measureFuncs.mbox.enabled bool true
.caps.config.image.sysimg.measureFuncs.mbox.calcMask int32 1924
.caps.config.image.sysimg.measureFuncs.mbox.maxCount int32 3
.caps.config.image.sysimg.measureFuncs.mcircle entry
.caps.config.image.sysimg.measureFuncs.mcircle.enabled bool false
.caps.config.image.sysimg.measureFuncs.mcircle.calcMask int32 1924
.caps.config.image.sysimg.measureFuncs.mcircle.maxCount int32 1
.caps.config.image.sysimg.measureFuncs.mline entry
.caps.config.image.sysimg.measureFuncs.mline.enabled bool false
.caps.config.image.sysimg.measureFuncs.mline.calcMask int32 1924
.caps.config.image.sysimg.measureFuncs.mline.maxCount int32 0
.caps.config.image.sysimg.measureFuncs.reftemp entry
.caps.config.image.sysimg.measureFuncs.reftemp.enabled bool true
.caps.config.image.sysimg.measureFuncs.reftemp.calcMask int32 1924
.caps.config.image.sysimg.measureFuncs.reftemp.maxCount int32 1
.caps.config.image.sysimg.measureFuncs.script entry
.caps.config.image.sysimg.measureFuncs.script.enabled false
.caps.config.image.sysimg.measureFuncs.script.maxCount int32 0
.caps.config.image.sysimg.measureFuncs.spot entry
.caps.config.image.sysimg.measureFuncs.spot.enabled bool true
.caps.config.image.sysimg.measureFuncs.spot.calcMask int32 514
.caps.config.image.sysimg.measureFuncs.spot.maxCount int32 3
.caps.config.image.sysimg.visualMarkers entry
.caps.config.image.sysimg.visualMarkers.enabled bool false
.caps.config.image.sysimg.visualMarkers.spot entry
.caps.config.image.sysimg.visualMarkers.spot.enabled bool false
.caps.config.image.sysimg.visualMarkers.spot.maxCount int32 0
.caps.config.image.sysimg.visualMarkers.arrow entry
.caps.config.image.sysimg.visualMarkers.arrow.enabled bool false
.caps.config.image.sysimg.visualMarkers.arrow.maxCount int32 0
.caps.config.image.sysimg.visualMarkers.box entry
.caps.config.image.sysimg.visualMarkers.box.enabled bool false
.caps.config.image.sysimg.visualMarkers.box.maxCount int32 0
.caps.config.image.targetNoise entry
.caps.config.image.targetNoise.enabled bool true
.caps.config.image.targetNoise.targetNoiseMk int32 55
.caps.config.image.zoom entry
.caps.config.image.zoom.enabled bool true
.caps.config.image.zoom.maxFactor double 2
# ID 645XXXXXX
# CRC01 XXXXXXXX
Is 4.11.0 not hackable?
« Last Edit: September 04, 2016, 10:29:40 pm by xbnipx »
Offline tomas123
Re: FLIR E40 Hack Help S/N:645XXXXXX F/W: 4.11.0
« Reply #1 on: September 05, 2016, 08:01:25 am »
you are the first user with FW 4.11.0
there are different Exx versions with different methods for manual firmware updates:
old FLIR Exx P/N:490xx (2.23.14) Update Pack
http://support.flir.com/SwDownload/app/RssSWDownload.aspx?ID=127
Exx Late 2013:
FLIR Exx P/N:645xx / 646xx (4.10.0) Update Pack
http://support.flir.com/SwDownload/app/RssSWDownload.aspx?ID=194
I think, you know this thread:
https://www.eevblog.com/forum/thermal-imaging/flir-e40-upgrade-configuration/
after reading this, you are a qualified hacker  ;)
« Last Edit: September 05, 2016, 08:03:06 am by tomas123 »
Offline tomas123
« Reply #2 on: September 06, 2016, 02:32:27 pm »
as I wrote two years ago:
Most mistakes ... comes from wrong using crc01, wrong editer and wrong cr/lf.
I copied your informative post to the right thread.  :-+
Thanks
PS:
My favorite method for calculating CRC01 is native bash mit CRC32.
see this sample:
calc a new checksum crc
// crc32 sample on bash command line
// count lines
$ wc -l calib.rsc
     646 calib.rsc
//print last line
$ tail -n1 calib.rsc
# CRC32 4683a151
//calc a new crc32 for (n-1) lines
$ crc32 <(head -n 645 calib.rsc)
4683a151
first try this steps with an original file
inside the large E4 thread in this forum you find some more methods for calculating the Flir CRC
« Last Edit: September 06, 2016, 02:42:13 pm by tomas123 »
Offline miami123
« Reply #3 on: January 18, 2019, 02:24:01 am »
I try to upgrade E40 1.0 sn645xxxx.  soft 3.18.0.   When I make upgrade resolution is ok but there is no function ( no pints, box) and I see errors apccore.exe
How to hack E40 3.18.0 (with max), I must first upgrade or downgrade software?
thx
Offline Dante91
« Reply #4 on: November 25, 2019, 02:03:34 pm »
Hello every one.
I am a new member. I would like to hack my FLIR E40 in 320x240 resolution. Do you have a solution about this ? I have already read the E40 and E30 subject, however I did not find a solution. I have not seen the tutoriel yet.
Friendly regards,
Dante
Offline reallybigone916
  • I'm Jimmy and Jerry
« Reply #5 on: September 03, 2020, 09:43:55 pm »
I was able to upgrade my E40 (with MSX 64501) with Firmware 3.18.0
Just modify the conf.cfg in FlashFS\system\appcore.d\config.d
Remember to get a new CRC01 code.
.caps entry
.caps.config entry
.caps.config.revision text "1.0"
.caps.config.image.settings.downsample bool false
.caps.config.image.settings.resIR int32 320
.caps.config.image.sysimg.alarms.humidity.enabled bool true
.caps.config.image.sysimg.alarms.insulation.enabled bool true
.caps.config.image.targetNoise.targetNoiseMk int32 0
.caps.config.image.zoom.maxFactor double 4
.caps.config.ui entry
.caps.config.ui.archive entry
.caps.config.ui.archive.enabled bool true
.caps.config.ui.archive.export entry
.caps.config.ui.archive.export.enabled bool true
.caps.config.ui.archive.sketch entry
.caps.config.ui.archive.sketch.enabled bool true
.caps.config.ui.archive.text entry
.caps.config.ui.archive.text.enabled bool true
.caps.config.ui.archive.voice entry
.caps.config.ui.archive.voice.enabled bool true
.caps.config.ui.fusion entry
.caps.config.ui.fusion.enabled bool true
.caps.config.ui.fusion.PIP entry
.caps.config.ui.fusion.PIP.enabled bool true
.caps.config.ui.fusion.PIP.locked bool false
.caps.config.ui.laser entry
.caps.config.ui.laser.enabled bool true
.caps.config.ui.laser.positionMarker bool true
.caps.config.ui.image entry
.caps.config.ui.image.startMode text "IR"
.caps.config.ui.measure entry
.caps.config.ui.measure.externWindow entry
.caps.config.ui.measure.externWindow.enabled bool true
# ID 645XXXXX
# CRC01 XXXXXX
