Hi frenky,
If it's any help to you, here's the changes I made to your software to get it working with the M1, I also had to make changes to support the new csv format. I've just ignored the second array of values after the temperature values. Any idea what these values are?
I've marked all my changes with "// CK" so you can see where and what I've modified. I used ThexConvertGUI-0_3 as the source.
One thing I have noticed and need to fix, is the software with my changes throws an exception if there are negative temperature values in the csv.
Thanks again for the original software.
