OK, some testing has been done.....
I programmed all of my Linear Flash cards with the data from my original AMBER provided card. The data copy was verified and my CSM Omnidrive is a very reliable programming tool. None of the cards would work in the second Radiance 1 camera that I thought was faulty
I then tried all of the cards in my original, working, Radiance 1 and ...... most of the cards worked fine ! The ones 3 that did not work weer not a surprise as they are later technology and somewhat different to the original linear Flash cards. I attach a photo of the cards that I tested. The ones on the right work with my original camera. The ones on the left do not work in either camera. The question is.... why do the cards work in the original camera and not in the second unit that I thought was faulty ? My immediate thought was software revisions in the camera. There are several IC's in the camera that are programmed and I remembered one on the PCMCIA port PCB. I suspected that this IC might influence Linear Flash card compatibility. Mu original camera has V1.1 on this IC whilst the second camera has V1.0 on the same IC. The other programmable IC's show the same version numbers. I believe teh V1.1 configuration may provide wider Linear Flash card compatibility. Can the V1.1 IC be duplicated ? No idea. That is an investigation for another day.
The original PCMCIA PCCard is a FUJITSU 1MB Linear Flash card with the model number "81011-20". It works in both cameras without any issues.
As a side note, the behaviour of the cooler diffres at switch on depending upon whether the camera is booting or not. When the PCMCIA card is absent or not compatible, the camera starts the cooler as soon as the power switch is operated and the cooler just "does its thing". If the camera starts properly and boots with a compatible card, the cooler behaves slightly differently..... the power switch is operated and the cooler briefly starts, then stops and waits for the camera to get to a certain point in the boot sequence before restarting.
I discovered the direct connection of the lithium cell to the two DALLAS IC's using simple continuity checks. I expected the RTC+RAM to be connected to it, possibly via a diode (not present) and checked the other DALLAS IC after seeing that it is a microprocessor power management IC with a backup battery input.
Fraser
